Hi All
Does anybody have experience of bleeding Hayes HFX9 without the official bleed kit? Spent a good hour last night with little success, method used was
1. Bike positioned so caliper is higher than lever (idea being that the air bubbles flow upwards and exit via the bleed screw)
2. Master cylinder cap removed, resevoir kept topped up to prevent air being drawn in through the master cylinder.
3. Press down on lever, open bleed nipple 1/4 of a turn, wait for 1-2secs, close bleed nipple, let go of lever.
4. Fill up resevoir, keep repeating point 3-4.
We got some success as we could feel the lever firming up, which suggests that air was evacuating the system, but having got a 'better' lever feel on a couple of occasions, successive pulling on the lever seemed to make it worse. I suspect that there isn't a good seal where the hose was reattached to the caliper and air is entering the system at this point.
Any comments/experiences welcome
