HELP! What bottom b...
[Closed] HELP! What bottom bracket do I need?
[#3764476]
I've got a 2011 Specialized Stumpjumper Pro Carbon frameset and a Shimano XT M760 chainset.
Bottom bracket is press fit type, which is new technology to me.
Specialized website says that bottom bracket is 84.5mm.
So, what bottom bracket do I need that is both compatible with the frame and the M760 cranks?
Thanks.
Posted : 12/03/2012 2:07 am
can anyone help?
Posted : 12/03/2012 11:45 am
You need a Specialized SM-BB91-42A adapter - only available from them, via your local dealer. Hope they're in stock, can be a long wait otherwise!
Posted : 12/03/2012 11:55 am
Are they HTII cranks?
edit: just saw above.
Posted : 12/03/2012 11:58 am
amazing, thanks njee - do you just know this or do they publish this information on the web anywhere? - damned if I could find it on the Specialized site.
won't be building it up until April probably so not in any great rush.
Posted : 12/03/2012 12:12 pm
Please double check this, but I think you need a BB-91-42A.
I've got a 2010 Carbon FSR & have been wondering about this myself. I have a feeling that the shell width is not standard, so it has a different width inner sleeve....
I THINK it is this:
http://www.mcconveycycles.com/store/product/13561/shimano-xtr-42a-press-fit-type-bottom-bracket/
but, as said, please double check. It might be worth sending an e-mail or calling Spesh UK to confirm.
Posted : 12/03/2012 12:13 pm
njee20 - do you know whether the BB had an inner sleeve? Or whether it's just the cups that press in?
See this pdf to see what I'm on about:
What is different about the BB on the Spesh that means you can't just use a 'normal' BB91?
Posted : 12/03/2012 12:18 pm
Specialized have given me a part number - item is in stock.
Posted : 12/03/2012 4:13 pm
brakes - Member
Fancy telling us the part number?? 😀
Posted : 12/03/2012 11:37 pm
sorry, just seen this
part number is W93940016
just picked it up from Cycle Surgery today
£40 seemed a bit steep, hoping it lasts
Posted : 24/03/2012 9:28 pm
