Help me understand ...
[Closed] Help me understand what the doctor said
[#3878770]
I went to the doc this morning to get a medical certificate for a race and he took my blood pressure. it was 10.9 which he said was quite low for a person with my level of fitness.
any doctors would care to explain to me?
cheers
Posted : 16/04/2012 10:13 pm
10.9 is not a blood pressure.
Blood pressures are stated as a systolic/a diastolic, so you get 120/70 or 140/90. What did he actually say?
Posted : 16/04/2012 10:15 pm
100/90?
Posted : 16/04/2012 10:16 pm
Are you sure that was blood pressure and not blood sugar level ie. did he prick your finger then tell you?
crikey - Member
Aren't there are different scales (like Celsius and Fahrenheit)
I know this is probably a stupid question...but why didn't you ask your Dr to explain!?
Posted : 16/04/2012 10:17 pm
[i]Aren't there are different scales (like Celsius and Fahrenheit)[/i]
No, there are not.
Posted : 16/04/2012 10:18 pm
not a doctor, but you can get really faint and even collapse w/ low blood pressure often leading to easily getting head rushes (Orthostatic hypotension)
[url= http://www.nhs.uk/conditions/Blood-pressure-%28low%29/Pages/Introduction.aspx ]hypotension[/url]
[url= ]Blood pressure chart[/url]
10 isn't a blood pressure level it seems
Check out the link. But you probs dont have hypertension, I guess if your GP is cool w/ it then there aint no need to be concerned. Hope that helped 🙂
Posted : 16/04/2012 10:19 pm
if it's blood sugar, it's quite high. Diabetic?
Worth saying twice imho.
So if you pressure WAS low, did the dr offer to test for anything such as anemia?
Posted : 16/04/2012 10:21 pm
Whatever the actual blood pressure was, I'm surprised to learn that low blood pressure is apparently unusual in people with a good level of fitness (I assume the op is fairly fit) I didn't know that. My blood pressure tends to drop the fitter I am.
Posted : 16/04/2012 10:22 pm
Let's keep guessing - maybe 109 systolic?
Posted : 16/04/2012 10:23 pm
mastiles_fanylion - Member
What? What on earth would anaemia have to do with BP?
Posted : 16/04/2012 10:24 pm
On the NHS site...
How much exercise you do: initially, exercise will raise your blood pressure, but if you are healthy and exercise regularly, your blood pressure will be low when you are resting.
TJ probably nothing - I thought it did but clearly wrong.
Posted : 16/04/2012 10:25 pm
It was blood pressure. In france it's stated like that. 10 is rather low, 12 is normal and above is high. there must be different scales.
I did ask the question and he said something like 'is it normally like that?' as if I know.
I'm not worried, just curious. I thought low pressure is good as long as you don't get headrush when you get up (i used to until I went on the i-you-know-what,must have been a sugar issue).
Posted : 16/04/2012 10:26 pm
mf : I thought that exactly. High while you're exercising or after and generally low when you're at rest.
Posted : 16/04/2012 10:27 pm
UK scale is mm of mercury as a pressure measurement and will be as crickey says. there should be two numbers tho even using differnt scales. could be cm of mercury?
Posted : 16/04/2012 10:28 pm
crikey - Member
druidh - Member
crikey - Member
No, there are not.
MrsMugsy - Member
Thank you MrsMugsy
France?.... 🙄
It means your BP is 100/90, which is fine. Go race.
Posted : 16/04/2012 10:30 pm
Druidh, there are not different scales; there are different ways of recording it.
Posted : 16/04/2012 10:31 pm
The only thing I remember with those numbers is iron level. 12 is good, 10 is bordering on low. But that requires a blood test.
crikey - Member
France?....
Hey - at least they use Kilometres and not Miles 🙂
Ok - mr google he say the french use cm of mercury we use mm so their reading is 1/10th of ours. still should be two numbers tho - so your 10.9 to be low should be the systolic - which is not that low. i generally run at 105 / 55 or lower and have to stand up slowly
Posted : 16/04/2012 10:33 pm
Cholesterol level? In which case that's high!
Posted : 16/04/2012 10:35 pm
PAM = (PAS + 2 x PAD) / 3
This is the equation that relates the high number (PAS)and the low number (PAD) to the mean pressure (PAM)
Posted : 16/04/2012 10:37 pm
[url= http://singletrackworld.com/forum/topic/help-me-understand-what-the-doctor-said#post-3695434 ]Glad that's sorted.[/url] It's the same as the Spanish way.
Posted : 16/04/2012 10:40 pm
mine is 120/60 is that fit?
TandemJeremy - Member
Have you ever taken it between posts on a political thread TJ ?
I bet you stand up quick after you've posted on one of those.
I'd have to see a photo alexxx 🙂
Fitness is little to do with BP - if yo are hypertensive it might drop it a bit to normal levels - its what is normal for yo that counts
Posted : 16/04/2012 10:42 pm
Just using mean arterial pressure is fairly meaningless.
Posted : 16/04/2012 10:43 pm
LOL @ ernie
+ I win with 109 systolic 8)
Posted : 16/04/2012 10:44 pm
Crikey has got it... just add zeroes to what the french tell you. 100/90 is on the low side, but can be normal for someone of an athletic nature, in association with a lower resting pulse rate.
Don't sweat it, race hard, don't stand up too quickly first thing in the morning!
Posted : 16/04/2012 10:48 pm
As stated earlier 10.9 is not a blood pressure reading. If the doc took a blood sample and said this reading was low I would guess it was a haemoglobin reading. Used to measure your oxygen caring capacities amounts others. 10.9 g/dl (grams per deciliter) is a little low. Normal parameters being around 13.5-18.0 for males. 11.5-16.0 for females.
If measuring blood sugar (bm) then 10.9 is a little high.
if you are unsure of an answer always ask for an explanation.
I work in Anaesthetics as an ODP.
Hope this helps.
sherry - we have established that the french use cm / hg so their numbers are 1/10thof ours and it looks like from what Mrsmugsey said its actually mean arterial pressure in cm / hg she has been given or possibly systolic in cm / hg
Posted : 16/04/2012 10:49 pm
I type to slow on my phone ha ha! If using cm instead of mmHg you incorporate a decimal point but still need 2 values to obtain a mean. Either way, if its a mean or systolic its not that bad.
Posted : 16/04/2012 11:10 pm
 DrP
Was he on a CB radio??
"ten nine whiskey alpha...."
DrP
Posted : 17/04/2012 6:54 am
[url= http://www.mayoclinic.com/health/pulse-pressure/AN00968 ]http://www.mayoclinic.com/health/pulse-pressure/AN00968[/url] [url= http://www.cvphysiology.com/Blood%20Pressure/BP002.htm ]http://www.cvphysiology.com/Blood%20Pressure/BP002.htm[/url]
Posted : 17/04/2012 7:14 am
I went to the doctors last thursday with my father, he's 84. The doctor was looking at the MRI scan and kept saying it was 'vera te'
It was a while befor it clicked - 'vera te' = wear and tear.
Posted : 17/04/2012 7:04 pm
It's good to find out things about my wife from STW whilst I'm working overseas....
Posted : 17/04/2012 7:29 pm
[i]It's good to find out things about my wife from STW whilst I'm working overseas....[/i]
Either she's buggered off to France, or she's going a long way to the doctors....
Posted : 17/04/2012 7:32 pm
Posted : 17/04/2012 7:37 pm
