Had decided on this from Richer Sounds, but when we went to buy at £270 the local store was out of stock: in fact most of the country was out of stock. Stock is still limited, and the price has gone up to £350
Do we need to go full HD given the size of the room? We are maybe 12 feet from the TV. Not too worried about a smart TV as we have a Now TV box we can plug in.
Any recommendations of a specific TV we should consider?
Is that a 32″ crt you’ve got now or is 32″ the size of the casing? We’re looking to replace a 32″ crt soon but found current 32″ stuff looks tiny in comparison.
That’s a 24″ CRT. A 32″ flatscreen with a tiny bezel will JUST fit in that space, hence the request “Needs to be 32″ max to fit in the available space” – based on the measurements of the screens I’ve linked above
As andy says – the external dimensions of your CRT will more likely be closer to 42″. You think you don’t ‘NEED’ andy bigger but what’s need got to do with it and once you’re used to the bigger screen you’ll look back at 32″ as if it were some relic from a bygone era – like TV’s before remote controls. Anyway, no need to waste time deliberating over what TV to get, just buy a Panasonic and get on with your life.
I always look at John Lewis as they price match and normally have extended warranty thrown in, service is excellent and never any issue if need to return etc
We’d have massive physio bills from getting sore necks seen too, that pic is taken from my normal seated position 😉
thanks to all those saying “just go 42″, but as above, we’re already jumping from 24 to 32, the space from the side of the chimney breast to the curtains is about 750mm so a 40″ or 42” just won’t fit
32″ blimey that’s a bit big. Don’t Richer Sounds have the cheaper Samsung (non Smart) in stock either? I would go for that if they do, I got a Samsung a few years ago for that sort of price and it is great.
EDIT: Not an expert but most people seem to think external devices are better than having smart integrated, I have just got a Chromecast and it is like magic.
mefty – you’re dead right. I’ve got a 3 or 4 year old Samsung SMART TV in our bedroom – the built in smart features now operate so slowly it’s painful to use. much better to have eternal devices that can be upgraded cheaply and easily. All I want from my TV is the screen. Everything else is redundant as I plug it into my home cinema amp so I get audio from that and channel changing from other external devices.
Hmmmm will some of the TV’s you’ve linked to actual sit on the TV stand you’ve got (at the angle you need) without one of the legs hanging off the front???
It looks a little awkward as it is now so I’d say you’d be best off getting a new corner TV stand and as said above bring it out a little and you can have what size TV you want then…
Just forget the stand and wall mount it, which is how ours is in a similar space to yours (I’m not sure why the TV has to stop at the curtains rather than overlap in front of them, so you’ll easily fit a 40 or 42).
How many of you lot are married with a wife who cares about how things look as much as (if not more than) what telly she can watch? 😆
I showed Mrs NBT the 32″ version in John Lewis recently and she was appalled at “how big” that was, she went bananas when I suggested that for about £20 more we could get the 42″ version!
I did consider a wall mount, something like this
but again no go, even though you won’t actually see the bracket as the tv will be in front of it…
In the end I went to a local TV shop where I saw a tv that someone had traded in. 32″ linsar smart TV, full HD, 3*hmi, 2*USB, even a scart socket. £80. Perfect
Not sure the pic links will work as I’m on my phone, but here the old 24″ CRT next to the new telly
Wouldn’t you have been better asking extension/conservatory advice for the structure that would be housing the new media room before getting tv advice? 😛
Posted 7 years ago
Viewing 32 posts - 1 through 32 (of 32 total)
The topic ‘Help me find a new TV. 32", HD, not Tesco’ is closed to new replies.
