Help - Broken Washi...
[Closed] Help - Broken Washing Machine
[#3368539]
Ok, so this is clearly my fault it's broken, and my fault I can't fix it, but the drum isn't turning, fills and empties ok, the belt is still on and I can turn it by hand. I've had the top off, and the inspection hatch at the rear, but I guess I need to go in from the bottom to do much more.
It's a Bosch Classixx 1400 Express.
Anything I can check before calling a man?
Thanks.
Posted : 19/11/2011 5:47 pm
google
Posted : 19/11/2011 5:53 pm
Google says check the brushes and also there is a thermal/overload fuse on the side of the motor somewhere..
Posted : 19/11/2011 5:54 pm
Motor? I'm not suggesting you do any of the following, but here's what I'd do...
Have a look at the motor, any obvious damage?
see where the power goes in? check it with a multi metre, is power going in? If it is, then have a look at the switches, is anything up there broken? No? then call "a man." Although i found it cheaper to just replace the washer.
Posted : 19/11/2011 5:55 pm
Yes, I'm guessing brushes are the likely cause. I'll have a look for a thermal fuse thing.
Posted : 19/11/2011 5:56 pm
meehaja,
Thanks for the suggestions, part of the problem is I can't see the motor from the top. Tipping it over I can see that the bottom panel comes off, but that means resting it on it's side. Is that ok? Should I refit the transport bolts?
Posted : 19/11/2011 5:58 pm
I'm going with the carbon brushes too. only cost a couple of quid from an indi white goods shop.
Posted : 19/11/2011 6:05 pm
