Guys,
Would appreciate your help on this dilemma I’ve landed myself into…
Picked up what I thought was a good deal…
2015 Pinnacle Ramin 5 29er (£300)
Very clean, minor signs of usuage, rode well but only when I had it back home cleaning it, I noticed one of the spokes had snapped on the rear?
The front wheel had been changed to a new dt swiss x1900 wheelset (all good / no issues) but the rear had the original Alex Rims and deore hub…
In a rush to get it up and running I picked up a set of stans flow on superstar fuel hubs last night from an SS member on here but have now found out the hub width I need is 135mm not 142mm which I have picked up
I know the answer to my question in that the new wheels won’t fit but what do you guys recommend on changing the rear? Availability on 135mm hubs are almost non existent and I’ve not got much faith in the existing wheel should I simply replace the broken spoke.
Advice will be greatly appreciated; thanks in advance!
