Gore Sealed Cables
[Closed] Gore Sealed Cables
[#1812414]
Am I alright to replace the cables of Gore Sealed cables? I only ask as my rear cable is splintered perilously close to the clamp on the rear mech. I was hoping to keep the sealed element of the cables and just put in a new cable? Shouldnt be any problems should there?
Posted : 19/07/2010 10:22 am
'Normal' cables could end up wearing through the plastic liner if you have any too-tight curves in the system; although since you can't buy the inners by themselves you really have nothing to lose by seeing how standard ones will interact.
Get some 1mm heat-shrink tubing to finish your cable-end. It's better than a crimp as it won't start the fraying process by crushing the cable, and you can remove/replace as often as you like without the need to trim the cable.
Posted : 19/07/2010 10:30 am
Good idea on the heat shrink cable. Never thought of that approach. Seems daft that you cant buy the inners seperately.
Posted : 19/07/2010 10:36 am
Gore inner cables are available. Though not many shops have them. But they should be able to get hold of them through Madison.
Posted : 19/07/2010 10:49 am
I always cut the cable off at the mech clamp so never have any need for crimps.
Posted : 19/07/2010 10:51 am
