For those occasional alp trips would like to run a 1*9 setup,
anyone know wh makes a suitable hanger,bike has EBB and vertical drops
thanks
eh?
does it have a replaceable gear hanger/drop out piece?
if not I dont think theres an aftermarket hanger you can add to a vertical drop out frame
Your best bet is a saint rear mech that bolts onto the hub axle.
Stoner,no its a custom bit of steel so no replaceable hanger,thanks for the heads up on Saint
shame its not horizontal , coulda used a dmr chain tug 🙁
fit an alfine perhaps? thatd give you same as 1:9 ?
the DMR one is good. had one on a jackflash. but as trail_rat says only on trackends.
so Saint or gear hub is your only option.
You'll also need a cable stop if running a gear hub, but if you run continuous outer to a mech you wont - just zip tie to the frame.
short cage saint mech £50
http://www.chainreactioncycles.com/Models.aspx?ModelID=17134
saint hub £64
http://www.chainreactioncycles.com/Models.aspx?ModelID=3414
dont forget something to keep it on at the front end though stoner esp for the alps !
You can just use a cheap pressed steel mech hanger - about £2 from most bike shops. They slip over the axle and the QR holds them in place. You might have to file the hanger into shape if you've got cowled or otherwise non-flat dropouts but it works fine.
That's the one trail_rat. Used one on my ss jump bike for a while and it was fine (on horizontal dropouts) and have used one while waiting for a new mech hanger on another frame.
gonna struggle with that on a vertical dropout
Depending on quite how the dropout on your SS is designed, the DMR one could easily be modified by removing the "sticky out channel doobry" that slides along trackends and just clamp directly to the outside of the dropout. That way you could use an existing mech.
5mins with the angle grinder, then 15mins with a file and emery cloth to finish I reckon 😉
