Viewing 11 posts - 1 through 11 (of 11 total)
  • Frame Decals
  • footstomper
    Have managed to get myself a Titanium H/T Frame but would rather not have the decals. Before I try and remove them has anyone on here done this and what method did you use?
    stevied
    hair dryer to soften them works well..
    scotroutes
    I used nail varnish remover (acetone) to soften them and they came off with a little rubbing. The frame was polished anyway so a quick rub over with brasso/duraglit took off any remainder.
    teasel
    Acetone for cleaning Ti, for sure. Stay clear of IPA
    Local boy Macavity found the following info that’s worth reading…
    [/url]
    LordFelchamtheIII
    Don’t use acetone, that’ll probably ‘change the molecular structure of the paint’ peel hairdryer-softened-sticker off then remove sticky stuff with white spirit.
    scotroutes
    paint?
    LordFelchamtheIII
    Nowt wrong with IPA, nice pint too.
    LordFelchamtheIII
    Is it just bare then?
    LordFelchamtheIII
    If it’s just bare Ti, slap as much Acetone as you like at it.
    scotroutes
    That was my (possibly incorrect 😳 ) assumption
    footstomper
    Thanks People I will try the Hairdryer and acetone to clean off afterwards.
    Yes it is Bare. Cheers 😀
The topic ‘Frame Decals’ is closed to new replies.
