fox float rp23-air ...
[Closed] fox float rp23-air pressure
[#3633384]
can anyone tell me how much air you need to put in the the rp23 boost valve, i've just put 250psi in mine just to get the sag right?? is this right or is there something wrong with the shock?
Thanks
Posted : 01/02/2012 7:11 pm
forgot to add I'm about 15 stone
Posted : 01/02/2012 7:38 pm
you mean air chamber, the boost valve is pre-set, and nobody can know without knowing what bike you ride. If the sag looks okay then you're reet, they're okay upto 300 ish ...
Posted : 01/02/2012 7:44 pm
thanks for that,
Posted : 01/02/2012 8:00 pm
Usually a good starting point is your weight in lbs in psi. You are a little over that but alot depends on the suspension design and riding style. Have a look at the manual for your specific RP23 or download it from the fox website. The propedal settings for my 2008 RP23 are:
• (1) PROPEDAL Light
• (2) PROPEDAL Medium
• (3) PROPEDAL Firm
Having moved from a shock with a full lockout I found 1 & 2 to be too bouncy pedalling uphill but pp3 is just about right. It is a dream of a shock once bedded in.
Posted : 01/02/2012 8:35 pm
For the boost valve they usually recommend 1xPsi per lb in weight, so the [u]guide[/u] for you would be 210psi. Then +/- psi to suit riding style.
Posted : 01/02/2012 8:38 pm
thanks for that, one other question, there does not seem to be much difference when the pp is on than when its off, again is this right?
Posted : 01/02/2012 9:36 pm
Do you mean 'not much difference' when sat on the seat and weighting it or 'not much difference' when pedaling up hill? IMO you don't really see a difference until the pedaling comes in to play.
Posted : 01/02/2012 9:44 pm
 igm
What bike is it? Manufacturers have different tunes on the propedal to suit the bike. I'm going to get mine tweaked when I get it serviced as the number 3 setting is about where I'd like the number 2 setting to be in terms of amount of platform - TF reckon they can do this.
Posted : 01/02/2012 9:45 pm
thats a big help, I haven't actually rode it yet, build it up yesterday and just been "fine tuning" so i'll let rip tomorrow and see how it goes
Thanks
Posted : 01/02/2012 9:46 pm
All the above advice makes sense to me. I run 150psi rear and 75psi front (F120) and am 13st 9lb. Best bet is just to set your sag right and then try to remember the psi's! I fine the 1st pp setting does fine on ascents. How you pedal is important too - you can learn not to bounce like a kid on a space hopper eventually.
Posted : 01/02/2012 9:49 pm
igm -its a scott spark, the previous owner took the scott shock off and put the rp23 on instead
Posted : 01/02/2012 10:05 pm
 igm
A guy at work has a Spark - I'll ask him what he's got air wise.
Posted : 02/02/2012 7:13 am
 igm
No good - he has a DT shock.
Posted : 02/02/2012 5:24 pm
cheers mate, no problem, been out on bike, air is leaking from shock, ordered seal kit. 🙁
Posted : 02/02/2012 5:45 pm
You could try stripping and rebuilding without a new seal. Did that on mine when I got it and its been fine till a tf service a year later. Cleaning out the valve core helped alot too.
Posted : 02/02/2012 6:03 pm
thanks for that 😀
Posted : 02/02/2012 8:03 pm
On my Orange 5 I run my RP23 @ 190psi and I only weigh 75kg.
What pressure do you guys run?
Posted : 02/02/2012 9:04 pm
I had a RP23 on my yeti asr and ran it at 180psi and I'm over 90kg!!
I think a lot depends on bike style n riding style ❓
Posted : 02/02/2012 9:48 pm
1kg = 2.2lbs
75kg = 165lb
90kg = 198lb
In our survey of just 2 people we can conclude that:
With an RP23 on an Orange 5 the nature of the design means you run a little higher psi than your weight in lbs.
Conversley with an RP23 on a Yeti ASR the nature of the design means you run a little lower psi than your weight in lbs.
(Depending on riding style)
Posted : 03/02/2012 12:16 am
 igm
About right. At just over 100kg I run circa 245lb on my Alpine.
Posted : 03/02/2012 1:34 am
Same here, single pivot frame and having to run much higher pressure than on the fox website/chart....the shock is good for 300psi though so no drama.
Posted : 03/02/2012 9:53 am
 LoCo
As above shock rated for upto 300psi, this may overwhelm the damping though (rebound) so may need a tune to keep it slow enough.
Have a look at the setup guide here:
http://locotuning.co.uk/tech-info.html
Posted : 03/02/2012 10:58 am
I'm 11st, and have about 175psi in my Spark RP23. You do need a high amount of PSI for the Spark to pedal properly - what compress tune does the shock have? The Spark needs a medium tune at least.
If Propedal is working properly you should find it harder to push through the travel in the first 10% or so of the shock - although I'm sure LoCo can correct me 😉
Posted : 03/02/2012 12:27 pm
Have a ASR-5, and for my weight (93kg) the manual puts the figure for the RP23 at around 190psi. If you can find your bikes manual on-line you should be able to get the intiial setup info in that, most people will then adjust this to suit their own riding style.
Posted : 03/02/2012 2:23 pm
The manual for a Spark wont help, as it's specced with a DTSwiss shock.
You should notice the difference with Propedal on or off....
Posted : 03/02/2012 3:25 pm
Hi guys, I just got a new 2012 Fox RP23 shock with Boost Valve and Adaptive logic (Rebound tune M, Velocity tune M, Boost Valve tune 200) and installed it on my Spark. Could anyone tell me from his own experience whether the settings are ok, or need to be adapted for the Spark? Moreover, I used the RS mounting hardware 6*22,2mm but there is still a little side play on the shock with screws fully tightened, is this ok? I reckon not...
Getting the right air pressure looks to be quite tricky too, I tried 190 psi for my 85 kg, but after some posts here, I will probably end up a bit higher for a 9,5 mm sag...
Posted : 10/02/2012 6:17 pm
most of what you've put is a foreign language to me, but I've got the same shock on my spark and had to put 250psi in it for the right sag, i'm about 90kg, with the screws fully tightened the is no play at all,, not sure if this helps???? 8)
Posted : 11/02/2012 8:27 pm
I managed to set up the air pressure correctly, but what really surprised me was the side play...will have to use some 0,5 mm spacers for each side...
Posted : 15/02/2012 9:40 am
just out of curiosity what psi did you end up putting in
Posted : 15/02/2012 8:36 pm
I got to some 220 as far as I remember, but I will adjust that for sure after some proper riding...still too much snow everywhere... 🙂
Posted : 21/02/2012 3:20 pm
Take your shock pump with you on the next ride and add or subtract a bit until the bike rides how you want it to ride. Then note pressure for future. Im 74kg with camelbak etc and use 150 psi in Zesty RP23. If the pro pedal makes the shock locked out your using too much air. It should provide a stiffer ride but still provide full suspension action.
Posted : 21/02/2012 4:56 pm
