If they are anything like the The Ones, then bleeding is well easy once you get the ‘knack’ You have to let go of all previous experience (hope, hayes etc) and accept that it’s very different. In fact, it’s actually very simple and easy to do. If the brakes a brand new then even easier, if on the bike I recommend using those plastic clips that can easily be removed to position the lever body in a vice to correctly orientate (frees up a hand too).
Then it really is just attach a syringe to each end of the system, with a bit of fluid in each, and push-pul unil all the air is out. I tend to remove the lever body from the vice (or jig) to change it’s orientation, give it a few taps etc, then a few more push-pulling of the fluid to finish off with a little over pressure before replacing the grub screw…not too much, just a very gentle ‘there you go’ 😉
As you put a little pressure into the system (with the bottom now closed) be sure to give the lever a couple of very short (2-4mm) squeezes.
Did mine yonks ago, still bang on just don’t expect the organic pads to last past the car part 😛
