I’m just trying to work out if i can fit Disk brakes on my none disk braked frame.
The reason for this is multiple AND not just because i want the newest and bestest must have thing which is disk right here right now.
I have a YETI ARC-X CX Bike, some on here may be lucky enough to have one, they are a great ride and most importantly look good. So i’m not in a hurry to get rid although selling these second hand is quite easy.
The main reason i want to change to run disk is that i want to run 29er wheels and be tubeless. I’d like a wider rim hence the 29er in STANS Iron Cross. The only one available for Rim is the ALPHA 340 or the newer stronger 400.
Front end isnt a problem as i’ll just swap over forks for some with mouthing points which leaves me with the back end, It must be do-able, a few lugs and a bit of paint.
What do you think.
And yes i know should i should probably flog it and buy one with Disks on but i like it,
