Viewing 40 posts - 1 through 40 (of 52 total)
  • Fish in Spaaaace!
  • mrchrispy
    no planes and no conveyer belts but…..
    what would happen to fish during a rocket launch?
    would they get flattened at the bottom of the tank or would they remain floating/swimming at the same level?
    yetidave
    flattened, same momentum change as everything around them
    druidh
    Floating. As they are at the same buoyancy as the water, they have the same momentum change as everything around them.
    CaptainFlashheart
    Fish have no plaice on a space mission.
    Unless it’s just to look at some sort of cod science or something.
    Taff
    they would die surely…. doesn’t liquid change consistency in space meaning it would float away and the fish too?
    yunki
    these puns are only just turbot to start and I’m already feeling a bit seasick..
    molgrips
    Sink. The fish is neutrally bouyant because of the swim bladder, which is a small gas filled bladder. As the rocket accelerates, the pressure in the water increases and the bladder will shrink. Since it’s the volume of the bladder that dictates how bouyant the fish is, as the volume decreases the fish becomes less bouyant.
    Those super deep free divers experience the same thing. They have to pull themselves down using the rope at first, but the pressure shrinks their lungs after a certain depth and they start to sink.
    Oh.. just had a thought though.. The fish must be able to inflate or deflate its bladder according to its depth, mustn’t it? So if it were relatively mild acceleration it would probably actively be able to stay floating.
    druidh
    That
    philconsequence
    fish do have some control, although considering you can make a cods swim bladder pop by reeling it up to the surface too quickly i think a rocket launch might be considered slightly more than a ‘relatively mild acceleration’ 😆
    molgrips
    Well what’s the depth range of typical fish? Pressure goes up pretty quickly as you go down even 10m or so, and the effect of a goldfish bowl’s worth of water even under 5g isn’t going to be as much.
    In fact, since F = mgh the pressure is simply proportional to the depth, and to g which is what’s going to change in the rocket’s frame of reference. So 5g is like being under 5 times as much water. Well if a goldfish is in a tank at say 6″ depth, it’ll only be like being less than a meter under water. Well within the range of even a shallow water species I’d have thought. And the rate of change of pressure would be much lower than a quick dart to the bottom of a pond when the heron turns up.
    philconsequence
    as much as i appreciate your maths, and would be interested in the addition of the average acceleration of a rocket being launched….
    i was merely pointing out that a rocket launch isn’t mild acceleration 🙂
    as for a ‘typical fish’ without being as straightforward as to describe the physical attributes of the species, there are a lot of different fish out there living in very different conditions and depths…
    they took frogs up into space, i’ve touched the frog pods that used to be in the ISS 😀
    MrSalmon
    Float. Wouldn’t the force pushing up on the bottom of the tank be transferred through the water equally?
    Cougar
    I can’t believe how difficult we’re finding this, it’s not exactly rocket sci- oh.
    molgrips
    And I was pointing out that even significant acceleration would not produce significant pressure in a fish tank, compared to diving to even small depths in open water.
    piemann
    Ooh, ooh, I actually met someone recently that really is sending fish up into space.
    He’s the head of Japanese research group looking at bone mineral density amongst other things. He told me that the Japanese space agency approached him with a vague idea and that it has actually turned into reality. It was originally planned for sometime in October, launching aboard a Russian Soyuz (sp?) craft which will transport a container (tank?) of fish to the International Space Station.
    The experiment is designed to look at the effects of zero gravity on bone mineral density. Funnily enough, he told me that fish are actually the only animals that can feasibly (ethically) be sent into space now (without being permanently restrained the entire time).
    maxlite
    Is this a sequel to ‘Pigs in Space’?
    piemann
    Found a link. They left on the 23rd.
    Fish in Spaaaaaaaaaace
    bigrich
    they would be pressed against the bottom of the tank.
    stats
    A quick google search shows up 29.4m/s/s which is approx 3G
    The real question is; battered or breaded?
    neilforrow
    They float!
    molgrips
    No, it’s approx 3g, and that’s in addition to the 1g from gravity.
    The problem with photos of fish of course is that they may be actively swimming up or down, rather than simply floating or sinking inertly.
    Anyway – how are they going to aerate the tank? Those bubbly things won’t work properly at all, they’ll just create a sort of mad foam.
    alex222
    You must accelerate at a certain speed to reach escape velocity so there is no ‘mild acceleration’
    However they would float.
    molgrips
    Not so. Escape velocity is the speed at which a ballistic projectile would need to be launched from Earth’s surface to break out of its gravitational pull. You could reach space at 1mph if that’s what your rocket did. Just keep going up.
    CaptainFlashheart
    You can’t ask that! What if it was something like trout, and those were the only two options? People would be floundering around for ages, trying to work out which was the least horrid on their scale of taste.
    logical
    But what would happen if the rocket was on an escalator?
    alex222
    Yes you wouldn’t have to reach escape velocity if you wanted to orbit the earth. But you still have to overcome the acceleration due to gravity to leave the earths surface surely?
    richmars
    Just going up at 1mph isn’t getting into orbit, it’s like the chap in the balloon last week.
    portlyone
    We should ask…
    stats
    Yeah, the acceleration of the rocket is 3g. However the force exerted by the rocket is equivalent to 4g acceleration to overcome gravitational pull, hence the reduction in thrust as the rocket escapes earths atmosphere and gravitational pull. Any mass connected to the rocket will be exerted to 4g.
    alex222
    But that is buoyancy in a fluid and can only work within a fluid.
    The question is if you put a fish on a rocket and fired it into space would it be squashed or continue to float?
    Show me a rocket that uses buoyancy to fly.
    molgrips
    Only by a tiny amount. And you need to consider forces, because acceleration is as a result of force.
    F = ma
    So for a 85kg person, you need 85 * 9.81 Newtons of force ie 834N So if your rocket motor provides 835N of force, you’ll accelerate upwards, pretty slowly. At 0.011 m/s/s, meaning that after 5 mins of that you’d be going upwards at 3.5m/s or roughly 8mph.
    Define up!
    To get into AN orbit around the earth you need to end up moving in an ellipse or a parabola, which will involve some sideways motion. What happens to you (ie if you fall back down, continue into space, swing around one or more times, end up in a stable elliptical orbit, or a nice circular one) depends on how much sideways and how fast you were going up.
    alex222
    Don’t you also have to take into account the mass of the rocket.
    cupra
    This thread sums up why I enjoy this forum so much. The science related randmoness of it all doesn’t half put a smile on my face. I know, I’m easy pleased.
    As you were…
    richmars
    The gravitational pull doesn’t reduce much even when in orbit.
    stats
    No, but if you’re taking your goldfish to Mars it will.
    EDIT: wrote your instead of you’re, pedantry corner.
    richmars
    Is that a deep fried mars to go with the fish?
    molgrips
    He is right. In orbit, you are falling to Earth same as if you fell out of a window. It’s just that you are moving forward so fast that the ground is always falling away from you at the same rate. You are falling around the Earth.
    mrchrispy
    I knew this thread would be a winner 🙂
    it was that story about the Russians that got me thinking, I wondered if they’d need little seats for the cosmofish.
    personally i reckon they stay where they are butI can’t prove it, I’m banned from keeping fish. rockets…. I have a plenty in the underground lair but after the incident with the sharks and the lasers, no more fish!!!
    andrewh
    scaredypants
    I don’t mean to carp, but this thread started so promisingly and then began to flounder when you got all “scientific”
The topic ‘Fish in Spaaaace!’ is closed to new replies.
