@c klein87
cannot see moving from Thomson 31.6mm to any carbon fibre 31.6mm post would make much difference on a mountain bike
on a road or mountain bike using the smaller diameter 27.2mm seat tube, the post would make a bigger difference. there is a reason the big brands use the smaller diameter 27.2mm post on their hardtails (whilst retaining 30.9mm or 31.6mm for their suspension frames) and that reason is comfort
if you are talking about the differences in comfort on a 27.2mm road frame between difference choices of seatpost, I can speak with experience.
The Thomson Elite will be harsh compared to a carbon-tubed seatpost with bonded aluminium-alloy head/clamp, which in turn will feel harsh compared to a full carbon S-Works or Easton carbon seatpost, which in turn will feel harsh compared to a Specialized CG-R (Cobbler Gobbler) Roubaix-style carbon post which has a suspension damping element designed into the CF post head
27.2mm posts of any material always feel more comfortable than larger diameter posts because of the seat tube itself, combined with the smaller diameter and more flexible seat post in that size
