Exposure Max-D Inte...
[Closed] Exposure Max-D Intermittent failure when wet
[#3543635]
I've been running a 2011 S/H Max D for a 4 months, it's not had a great deal of usage previously and only ever fails in the wet, usually after a couple of hours on the commute home in the drizzle.
The light cuts out completely, in lit area's I'll not always notice immediately which is a bit dodgy on junctions etc, It'll then not turn back on straight away, I can usually get it going again in 'Full' mode, switching through the settings usually turns it back off again, anyone experienced this? Rough cost of an Exposure refurb?
Posted : 09/01/2012 1:38 pm
I have the same light, no issues so far. If it's a 2011 model, still within warranty?
Posted : 09/01/2012 1:42 pm
Nah it's a Second hand unit.
Posted : 09/01/2012 2:04 pm
Sounds like a failed seal and damaged circuit. I got my Joystick fixed (out of warrenty) for a total of £7 for a similar problem.
Exposure are pretty good at the repairs (and for decent cost) but they are not a shop so may take a few weeks to sort everything out for you.
Posted : 09/01/2012 2:08 pm
Have you got one of those rubber bungs to put in the charge-port?
They come as standard with this year's lights. A little water getting into there can confuse the internals and make the light switch itself off.
If that isn't it, then you'll probably have to send it back..
Posted : 09/01/2012 2:22 pm
I have a Joystick that does the same. Sucking water out of the charger port seems to help.
I did enquire about getting some of the plug seals that are on the new ones but didn't get an answer so instead I just plug the hole with some Blu-Tac
Posted : 09/01/2012 2:24 pm
Ah, I'll try the blue-tac!
Posted : 09/01/2012 2:42 pm
