Excel Help Please –...
[Closed] Excel Help Please – Race timing question
[#3265814]
I need Excel to return a time in hh:mm:ss when I enter a rider number in the adjacent cell.
Example : Where rider numbers are entered into the “A” column as they cross the line
In B1 =if(A1=””,””,NOW())
In B2 =if(A2=””,””,NOW())
In B3 =if(B3=””,””,NOW())
…and so on.
However, every time I enter anything the whole sheet recalculates the NOW() rather than just the dependant of the cell that the new entry has gone in.
The idea is that I’d enter a rider number as they cross the line and it would compile a list of numbers against times. The data is transferred into a table or a list that can be sorted to retrieve whatever stats I’m after.
Posted : 21/10/2011 10:03 am
Why do you need the NOW function?
Posted : 21/10/2011 10:05 am
To record the exact time that the number is entered. Perhaps there is a more suitable function... dunno... stumped.
Posted : 21/10/2011 10:07 am
use a macro and just one NOW
Posted : 21/10/2011 10:08 am
Sorry, I just turned my brain on. Your problem is that NOW is a live function. it'll recalculate to always give you NOW. You could hardcode it each time you've used it.
Have you got to record a lot of times?
Posted : 21/10/2011 10:09 am
hence use a macro to grab your now data and store it as a fixed datapoint in a list.
Posted : 21/10/2011 10:11 am
so, Id have at top of list in row 1
enter rider number in A1, have formula =NOW() in B1
then stick this in your VBA
Sub logtimedata()
' logtimedata Macro
' Macro recorded 21/10/2011 by User
' Keyboard Shortcut: Ctrl+q
Range("A1:B1").Select
Selection.Copy
Range("A3").Select
Selection.Insert Shift:=xlDown
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
:=False, Transpose:=False
End Sub
So when you type a rider number in a1, it refreshes the time, you then press ctrl+q and it copies the rider name and time into the row 3, shoving all the other stuff down a row at time
Posted : 21/10/2011 10:16 am
just change the calculation options in Excel Options, stop it from updating automatically
Posted : 21/10/2011 10:19 am
click on the office logo, choose excel options, then choose calculation options and set it to Manual
Posted : 21/10/2011 10:21 am
If we are using macros is there not a cell 'on-click' or after update option that can be used to set the adjacent cell to the value of NOW()?
Charlie - are you saying stoner hasn't just told him how to do it correctly?
Posted : 21/10/2011 10:22 am
Stoner has told him an alternative truth
Posted : 21/10/2011 10:24 am
Thanks fellas. Phone has just gone so I have to do my proper job again! Will have a play with this later.
Posted : 21/10/2011 10:26 am
This is dangerous... if you accidentally hit F9 or whatever it is on your system, all the NOW()s will be updated and you'll lose your timing information. I never trust Excel and recalculation - sometimes seems to do it on save, load etc. Safer to use the macro method suggested!
Posted : 21/10/2011 10:57 am
Posted : 21/10/2011 10:59 am
I would either:
1.ring up the Beastway team and ask then if you can use their software
2. ask if our timing team will assist (we use the beastway system)
3. pay £50 for the Pursuit cyclocross timing software
4. continue to try and write your own solution
we would use Pursuit if it could handle staggered starts, IIRC you don't have that issue. It looks really good with great information on the screens.
HTH, you know our email address 😀
Posted : 21/10/2011 12:44 pm
It is is for my own "amusement". We have competant timers at HtN with all of the necessary laptops and printers. We're paying them to do it properly.
I was just messing about with the NOW() function on a work matter and my mind wandered.
Posted : 21/10/2011 1:00 pm
no problem, just trying to assist
"We're paying them to do it properly"
we don't pay anyone (except the MRT "donation")
probably explains why we are "endearingly shambolic" 😉
Posted : 21/10/2011 1:11 pm
