Viewing 2 posts - 1 through 2 (of 2 total)
  • DX P7 torch not working
  • Lucas
    I have one of the MTE SSC P7 torches from DX. It was fine last year but I came to use it the other day after not using it for the summer and it doesn't work properly/at all.
    I turned it on and it would turn on but then started to flash while in a none flashing mode. Jiggling it around sorted it out temporally. But now it's not turning on at all. It's like it has a loose connection.
    I have recharged the batteries, I also noticed that the bulb unit was a bit loose on its threads so I've tightened that up a bit too. Still not working.
    Any ideas?
    couldashouldawoulda
    A common problem I think.
    Most common fixes are given here – with pics:
    http://www.candlepowerforums.com/vb/showthread.php?t=227518
The topic ‘DX P7 torch not working’ is closed to new replies.
