DT Swiss spoke calc...
[Closed] DT Swiss spoke calculator
[#1231758]
Anybody know what's happening there, only appears to have Mavic and Sun rims on there, and no hub options bar user defined or DT.
Posted : 17/01/2010 10:50 pm
Not been there for a while after getting a couple of dodgy results. I always use Roager's calculator at the wheelpro site myself.
Posted : 17/01/2010 11:18 pm
That's a bugger. 🙁
Posted : 17/01/2010 11:43 pm
It seems to come and go these days... I think it must be getting updated
Posted : 17/01/2010 11:46 pm
still having probs. with your Donkey unciy pete?
Posted : 17/01/2010 11:53 pm
Nowt that a beating with a spirit level won't cure.Think it may be that cress aversion.
Posted : 18/01/2010 12:50 am
When you click user defined you enter your own dimensions which you will either have from your hub manufacturer or have measured yourself.
Same for the erto on the rim i find it works perfectly fine
I found the wheelpro came up 1mm short when i used it but the dt was fine
Posted : 18/01/2010 11:38 am
