Drop Offs
[Closed] Drop Offs
[#1441920]
As an old, old skool rider, I don't take to new tricks very easily and it takes ages to build up confidence, learn how to do new stuff. What makes things worse is I ride 99% of the time in Suffolk/Norfolk so some of the more normal trail features (drop offs etc) are absent in my day to day riding.
A recent trip to Dalby highlighted my complete lack of technique and cohones when it comes to drop offs. I watched riders flow over them as if they weren't there but could I do it? No... and I embarrassed myself every time by chickening out. I don't mean the little ones that you can get air off but the (what to me) were precipitous drops with uncertain landings such as those muddy ones on the red/black section just after the Pace play area.
How the hell do you do them and how can I practice something when there is nothing much to practice on? The only thing I have found is a concrete pad for storing sugar beet which starts at about 8 inches and goes up to 2 foot. Trouble is there is no run off so you'd have to launch and then get on the brakes within nano seconds.
Help!
Posted : 24/03/2010 11:45 am
Learn to manual. There's vids on youtube. And you can practise that anywhere.
Once you can do that drop offs are easy.
Posted : 24/03/2010 11:49 am
How high are we talking? The technique for drop offs doesn't change much with height, but getting the speed right or adjusting for higher or lower speed is key. If its biggish and you are carrying speed then it helps to get nice and low on the bike to absorb the lip and stay fairly neutral, you can then let the bike move away underneath you before asborbing the landing. For lower speed more front wheel loft and more upright and rearwards stance is needed. Best thing to do is find a small drop and practice different speeds before building up.
Posted : 24/03/2010 12:09 pm
Skateboard parks usually have small drops you can play on - 18" or maybe a bit more. Or maybe I'm spoilt up in Notts where these are very common and all seem to have a similar design!
Like ddmonkey said, it's the same technique whatever the height - find a highish kerb and ride it until you can land both wheels at the same time.
Posted : 24/03/2010 12:17 pm
Manual practice here I come then!
I can launch off kerbs and land both wheels at the same time it is just when there is a cavern below the front wheel and the back wheel is still on the stop/drop off. All I see is me going over the bars and face planting.
Posted : 24/03/2010 12:40 pm
In that case slowjo you need to get confidence to go a bit faster, and you can only get that from finding some drops you can build up your confidence on. Try finding something that you can just roll, and then keep hitting it faster and faster until your are no longer rolling it but landing both wheels flat. Remember that speed, get it in your head by doing it over and over again, then when you approach a proper drop you know how fast to go to avoid the front wheel dropping. Its all about being able to judge the safe speed.
Posted : 24/03/2010 12:58 pm
A drop which is flat take off to flat landing (ie a step, not matter what size) is very different to a drop with a vertical top part and a transition to land in (much more common). For the first one manualling off is the way to go, for the second you may well only need to keep a little speed and let the bike follow the gradient of the landing.
Posted : 24/03/2010 1:06 pm
Yeah for many drops you might not need to actually manual, but the principle is the same, just less exaggerated, and being able to will make you more confident.
Posted : 24/03/2010 1:23 pm
Go and see Jedi, he gave me a boost on the drop off front.
Posted : 24/03/2010 1:49 pm
most of the technique required is in your mind, then there's judgement of speed
Posted : 24/03/2010 2:09 pm
+ 1 for seeing Jedi/skills course
Also the Fluid Ride Like a Pro DVD is pretty good at explaining drop and other techniques: [url] http://www.rutlandcycling.com/17587/X-treme-Video-Fluid-Ride---Like-A-Pro.html [/url]
Posted : 24/03/2010 2:32 pm
 jedi
if you manaul off a drop your are either going very very slow or are doing to much.
Posted : 24/03/2010 5:51 pm
You don't really manual you just move your weight back, push into the pedals and hold the front end up until the rear wheel starts to drop off. you definitely don't want to be manualling as the drops get bigger.
Posted : 24/03/2010 5:57 pm
Note that I didn't actually suggest manualling off a drop off. But being able to do it slowly means you've got the technique nailed rather than just relying on going fast and not having to do anything.
Similar to what you do manualling then, but less exaggerated - like I said.
Go and tell Andy from Dirt School that he's got it all wrong if you don't believe me. 😛
Posted : 24/03/2010 6:07 pm
Best way I can describe the feel / motion of the frame by frame picture above is imagine you're pushing a shopping trolley away from you really hard (substitute the handlebars for the trolley handle!). Time the end of the "push" to coincide with when your front wheel gets to the lip of the drop. this will move your weight back, keeping the front wheel up until your rear wheel drops off the lip.
As above though, practice!
Posted : 24/03/2010 6:14 pm
start small and work up. You can do a kerb, now find some bigger obstacles (12", 18", 2 feet and so on).
Surprisingly little effort and speed needed usually, esp as glenp says on gradient landings,
swinley spooking Mrs MC
[URL= http://i288.photobucket.com/albums/ll161/bikrbum-dave/DaveDropOfffiltered.jp g" target="_blank">http://i288.photobucket.com/albums/ll161/bikrbum-dave/DaveDropOfffiltered.jp g"/> [/IMG][/URL]
the much missed ladders at cwmcarn
[URL= http://i288.photobucket.com/albums/ll161/bikrbum-dave/IMG_0085a.jp g" target="_blank">http://i288.photobucket.com/albums/ll161/bikrbum-dave/IMG_0085a.jp g"/> [/IMG][/URL]
Posted : 24/03/2010 6:16 pm
Oh alright then, if we're showing photos 😉
Posted : 24/03/2010 6:26 pm
 jedi
dont put your arse back!!
Posted : 24/03/2010 6:27 pm
All the one's at dalby you can just roll off, just don't brake on them.
Posted : 24/03/2010 6:33 pm
I can't manual,or wheelie,but I can ride drop offs. The "how to" pages in the mags and the above sequence don't help me. I just try to ride a bit quicker and stay loose on the bike. Works for me.
Posted : 24/03/2010 9:08 pm
At normal speed, a quick pump (load and unload) of the forks on the lip seems to set me up nicely for most drops. Not sure if that's textbook tho.
Posted : 24/03/2010 9:23 pm
 jedi
the slower you go the more you have to do.
you drive with your feet
Posted : 24/03/2010 9:25 pm
I've heard all sorts of differing suggestions.
Just starting drop offs at the mo. I weight and unweight the bike as the front wheel gets to the lip. Am on flatties and don't really try to lift the forks?
Have a very neutral position and make sure I have some speed.
Suggestions on a postcard or stuck down envelope to...
Posted : 24/03/2010 9:35 pm
 jedi
unweight before the lip. keep your pedals in middle of foot not under your toes if on flats.etc....
Posted : 24/03/2010 9:38 pm
Yes, that's what I meant, I load and unload the bike at the lip of the drop. Although, some friends say they don't consiously do that, they talk about shifting their weight back a touch.
Posted : 24/03/2010 9:47 pm
will that partly explain the big hole in my shin after trying to follow the fast kids and not quite spotting the step down til just after the last minute last saturday?
 jedi
you do not load the forks!
Posted : 24/03/2010 9:49 pm
Thanks for the tip about foot placement. Could save my shins!
One thing I was told by a 50 y.o. german MTBer was 'stand on the pedals'. Seems to work for everything, uphill, downhill...
...that is don't think about moving your weight about, just try to stand on the pedals and your weight will be in the right position...
Posted : 24/03/2010 10:22 pm
 jedi
not quite 🙂
Posted : 24/03/2010 10:40 pm
B.A.nana -I taught the missus' to drop off on that - great place to practice riding up a ledge too.
This drop is local too:
Posted : 24/03/2010 10:47 pm
I wouldn't take this as advise because I've not got it perfected myself yet either but.....It seems to be a bit easier if you're carrying some speed as there's less time for the front to drop. You need to keep your weight back though obviously. The slower you go the more you need to do with the front end so there's more margin for error. This is what I have found anyway. Actually I have found that speed is your friend in most trail riding. There's a lot to be said for committing to the challenges that lay ahead. Most of my crashes so far have thankfully (touch wood) been low speed ones when I've fannied about and failed to scan the way ahead.
not quite
Yes, it seems to work for basics but...
...I guess I'll have to book a course to learn more! :)))
Cheers, ta.
Posted : 24/03/2010 10:49 pm
same here shit at drop offs,cant even pop a wheelie
Posted : 24/03/2010 10:52 pm
 jedi
no need. i'll explain as always on here best i can!
Posted : 24/03/2010 10:59 pm
alright i feel like a bit of a nob now- can i expect to be able to do drops like that on a p7 or have i got an excuse with not having full suss or an extreme bike. ive done the things on the orange at learnie but you land on a hill there and its only about a foot so a bit of momentum does it.
Posted : 24/03/2010 11:04 pm
Hardtail is fine!
Posted : 24/03/2010 11:13 pm
 jedi
its not about the bike
Posted : 24/03/2010 11:15 pm
 jedi
[img] http://images.fotopic.net/?iid=yzm5f4&outx=800&quality=70 [/img]
[url= http://www.chocolatefoot.co.uk/journal/wa/archives/2003/05/000043-a_long_way_down.html ]dropping on the hummer[/url]
not about the bike as i said
Posted : 24/03/2010 11:36 pm
[img] http://lh6.ggpht.com/_By42uYleqms/S6qWkROOYKI/AAAAAAAAGXI/PJ2q2ipReJc/s640/vicki%20jump [/img]
from before digital cameras - will it even work
Posted : 24/03/2010 11:38 pm
jedi is that actually a helpful video or pic for drop off technique or are you just showing off?
Looks like you're going pretty slowly and 'hucking' off the top in the video. Very impressive but not what's normally considered good technique for drop offs I thought.
Posted : 24/03/2010 11:55 pm
 jedi
yeah granny gear. last minute push.
just showing hardtail or fullsuss dont matter
Posted : 25/03/2010 12:02 am
mines must be bad technique too compared to the advice being given ....
some folk look lined up to do backflips .... you can get away with that off small drops but do that off anything big and your gonna loop out !
stay neutral till you know what your landing on ... you dont want your weight way back if your landing on a slope as steep as the one in the photo.....
although first rule would be look before you leap - got caught out with that a few times when i was younger
a mate of mine actually revisited that drop off recently and broke both his collar bones from leaning too far back while going off it
Posted : 25/03/2010 12:05 am
singletrack rider follows advice he got off the forum ....
Posted : 25/03/2010 12:14 am
 jedi
heh heh
Posted : 25/03/2010 12:15 am
Munqe-Chick, did you used to be Munqe-Bloke before you started riding drops like that? Looks like a sure fire way to lose the wedding tackle from where i'm sitting.
Posted : 25/03/2010 7:13 pm
