I’ve just built mine up. Im 6ft’2 so the normal bolt always felt a bit small/cramped – this is a much better fit.
I originally was going to buy an absolut sx which is pretty similar, but the bolt is just a little taller/longer.
It is heavy but its also pretty bulletproof, I built mine up after my mondraker kept falling apart – with the idea that it could be taken to the middle of nowhere and nothing much would break (steel frame, coil shock, coil forks, alfine, cable brakes, big’ol bearings).
It’s a fun bike, I wouldnt want to ride it on long all day-rides regularly, but as a do-it all I’m pretty happy with it.
Thanks, it was your advice a few months ago to look at the absolut sx/bolt/kona a that prompted me to try one. 😀 It works well with the alfine – no faffing with tensioners!
Looks like you’ve built the bike I originally wanted in that case, no wonder I like it.
I’ve put horizontal dropouts on mine now to get rid of the home bodge front tensioner but I’m thinking of getting one of those oval chainrings. Partly as I need a new one & partly as I’ve read they can reduce suspension bob, in which case I’ll go back to the vertical ones & a rear tensioner.
I’ve been pestering dmr to sell me their 853 prototype but as yet they’ve not caved in. It’s supposed to be much lighter.
I think it climbs fairly well for what it is, but I havnt really done enough riding on it to comment on long ascents. Itll hopefully be comin with me to morocco in a couple of months, (hence all the cables/coils that can be fixed with a hammer). So will see how well it climbs then. The shock makes a bit of difference, I didnt like the air shock – With the elka you can dial out any pedal bob and drop the forks to 125mm and it climbs pretty well.
Podge – the same frame in 853 would be 8) 8) 8) – I guess it just worked out too expensive for DMR to make. They arnt cheap even in 4130 steel (I managed to get this one second hand fortunately)
There is a review of the bolt long on the Ride it out website. My buddy also has one out in Morzine and loves it, it gets thrashed pretty hard and hes fitted 160mm forks. They are pretty tough bikes and can take alot of stick.
Posted 10 years ago
Viewing 12 posts - 1 through 12 (of 12 total)
The topic ‘Does anybody have a DMR Bolt Long?’ is closed to new replies.
