The pump in my dirtwoker wouldnt work this evening. The little green light on the plug comes on but the no noise from the pump.
I tried all the IT tricks of turning it off and on, unplugging it and plugging it back in but nothing. Ive only had it a couple of months and everything was fine last time I used it a week ago.
Obviously I have no proof of purchase so guarantee.
What should I do? How do I trace and fix the problem?
I found mine does that when the engie in the car isn't on. Must be low power to the 12v.
Thanks Spud but no. Ive just popped out to try it with engine running but nothing 🙁
I seem to remember ime getting "jammed" once - think it was down to an air lock somewhere.
To be honest, I banged it on the floor a few times and it started working when I filled it back up!
Check the inlet filter on the hose at the botton of the tank, mine got blocked after filling it from a manky outside tap.
