Viewing 12 posts - 1 through 12 (of 12 total)
  • dice trick- any magicians here?
  • roper
    I have a friend who will hand you a regular 6 sided dice, ask you to pick a number to go on top and leave it in a box. without looking he can tell you what the number is. He always gets it so how does he do it?
    Anyone willing to break their magic code to demonstrate how stupid I am?
    King-ocelot
    Not sure if I understand the trick. But can he see inside the box? From seeing one side of the dice you can tell what’s on the other. Opposite sides add up to 7 etc.
    GrahamS
    Any chance he could see the bottom of the dice somehow?
    (Since the opposite sides always add to 7)
    roper
    he can do it with his back turned or out of the room.
    When he uses the box it just keeps the dice out of site. It is wooden and velvet and you can’t see the dice at all.
    scaredypants
    can he do it without the box ?
    roper
    Yes he can do it when I hold it in my closed fist too, or under any object.
    King-ocelot
    With any die or just the one he uses?
    roper
    if you use the box he has three and let’s you pick one.he did it again today with just the one he had.he doesn’t touch it other than handing it over.
    shermer75
    scaredypants
    Well, I could tell you but I’d have to saw you in half afterwards
    shermer75
    We should ask Roger Lapin, one of the finest magicians in Poole
    GrahamS
    Orientation sensor and radio transmitter built-into the dice then!
    Or he’s just very good at reading you. Try picturing a different number to the one you selected.
The topic ‘dice trick- any magicians here?’ is closed to new replies.
