It looks a lot neater on a black frame like Dirtyrider’s, because you can’t see the wires. On a white frame it looks a bit crap IMO.
As an aside seeing Dirtyrider’s – you can put the ANT+ adapter in the BB shell, plugged into the junction box, works fine! Can rattle a bit, so you may want to tape it in, looks neater. Only works with internal routing obviously.
Anyone bodged internal di2 onto a frame that was meant for internal mechanical only?
Can’t see why it wouldn’t work. May have to drill out some of the cable stops slightly so that wires go through rather than just cable inners. Need reasonable access at the BB too to fit everything in.
