Is the shock in perfect working order??
If you got it 4 weeks ago I presume it’s brand new or brand new bike?? Some revised parts on the newer ones.
I’m chuffed to bits with mine on a Lapierre Zesty. Had a problem with the chirping on compression due to oil getting past the diaphragm.
Sent it to TF Tuned whom were excellent and aloneg with a service, they fitted uprated parts as I’m the 2nd owner.
I set mine up with approx 35% sag 9 clicks from minimum on Lsc.
1 turn from max on Hsc
12 clicks from minimum on Lsc
1 1/2 turn from maximum on Her
Pressure @ 190psi
I weigh 95kg and this is spot on. Supple over small bumps but doesn’t bob too much due to Lsc.
Then it can also handle big jumps to flat 3ft without bottoming right out so I think the perfect set up.
Flick the CS if you have a big slog and it firms right up for climbing otherwise I leave for short burst/rough/switchback climbing.
Key is knowing what you want and adjusting it bit by bit to know how you got the adjustments
Hth
