Crud Road Racer Mud...
[Closed] Crud Road Racer Mudguards
[#1044814]
Anyone using [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=42448 ]these[/url]? How do they fit round close clearance road calipers?
I have no respect for my road bike, so don't care if they look shit!
Posted : 16/11/2009 4:19 pm
My brother has some, he rates them quite higly and they look OK too, IMO
Posted : 16/11/2009 4:21 pm
Hardly notice them, fit under standard Dura-Ace calipers and keep the road spray to a minimum. Anything else?
Posted : 16/11/2009 4:24 pm
i've got a question - can they [i]only[/i] be mounted on the front if you have a caliper brake to attach them to? if not, is it possible to get them close to the front tyre with no front brake, and a larger gap up from guard to crown?
Posted : 16/11/2009 4:27 pm
[i]Hardly notice them, fit under standard Dura-Ace calipers and keep the road spray to a minimum. Anything else?[/i]
Nope that'll do for me. On the Christmas list they go. (anyone got Santa's address?)
Posted : 16/11/2009 4:30 pm
 JoB
they fit under close clearance road calipers fine, because they're designed to
if you haven't got a front caliper to mount them to i guess you could put a bolt through the hole in the fork and strap the guards to that, might require bodging
Posted : 16/11/2009 4:33 pm
cheers for the info.
Posted : 16/11/2009 4:35 pm
I have attempted to fit these mudguards to a cross bike with Cantis, the problem is there is no brake bolt to hang the mudguard from, I tried mounting them to the crown of the fork/frame but the distance was too large and they rubbed on the tyre at the rear. I then tried making a spacer but that was pretty crap.
I ended up putting my SKS Race Blades back on with a cable tie to attach them to the crown of the fork/frame.
The Crud guards are also pretty flimsy, I know they are designed to break if they get caught in your machinery, but they don't look like they will last long. I am sticking with the SKS Race Blades.
Doug
Posted : 16/11/2009 4:36 pm
So, basically you've attempted to use them for something they are not designed for, and due to them not working you think they are crap?? 🙄
Posted : 16/11/2009 4:45 pm
Take them off before sticking your bike in the car! I now have to straighten one of the arms - doh!
Posted : 16/11/2009 4:47 pm
I've got a set I've fitted but don't now need. Will do them for £15 posted if anyone is interested.
Email in profile
Posted : 16/11/2009 4:52 pm
I couldn't use the forward extension of the rear mudguard without it fouling the tyre. In fairness, I had as much rubber under the brakes as I was going to et away with, so I'm not surprised. Wettest ride in today I''ve had for a while, and my feet and backside in particular arrived a lot drier than I expected. I like them, and they look vastly better than raceblades. 🙂
Posted : 16/11/2009 5:12 pm
Maltloaf, I guess having them before Xmas won't hurt. ygm
Posted : 16/11/2009 5:15 pm
 JoB
if you want to fit guards on a 'cross bike you've bought the wrong bike and should have got a tourer with the ability to fit a nice proper full set of mudguards on
Posted : 16/11/2009 5:19 pm
JoB's got a point there!
Posted : 16/11/2009 5:22 pm
I bought them for my touring bike as I hate propper guards with a passion (shocking looks, disproportionate weight, noisy, not exactly aero, snap-tastic, need adjusting ecary time the bike gets clattered in the rack).
Anyone got a bodge to fit them?
Or care to recomend some good touring guards that actualy work in the real world? Mr Crud, are you out there? Can you make one (or just addapters) for touring bikes pretty please?
Posted : 16/11/2009 5:30 pm
Nah, Jo's just a mudguard Nazi (Godwin?) 🙂
Posted : 16/11/2009 5:52 pm
 JoB
i'm a YouThinkYoureTooCoolForATouringBikeSoYouBoughtACrossBike Nazi actually
Posted : 16/11/2009 6:00 pm
I didn't have any of those problems with my SKS chromoplastics attached to proper mudguard eyes, apart from the aero point, but when I'm commuting in the rain and wind with a bunch of stuff I'm more worried about being dry than being aero. Looks are for you to decide, but I quite like the look of bikes that have been well designed for their function.
Posted : 16/11/2009 6:09 pm
Dont fit on my Giant SCR3 with 25c tyres and I suspect they may not even fit with 23c tyres either as the arms dont quite seem long enough so I have switched back to front race blade and rear bolt on SKS.
Posted : 16/11/2009 6:11 pm
see i've got this fork:
(though not attached to the same bike as above) and want to achieve a nice snug fit for the front guard, but don't know what is used in this pic:
or where one obtains one!
A guy at work has the cruds and hates them. We all use Race Blades, and unless you're the guy sat behind them and aren't bothered about how they look they're better it'd seem. Bits keep falling off his! The end bits of the flaps, the bushings etc.
Posted : 16/11/2009 6:13 pm
Theflatboy - I'd hazard a guess that's a cork. Or, if it isn't I think a cork would probably work. 🙂
Posted : 16/11/2009 6:24 pm
Jo, what's your take on a cross bike for racing and commuting on during the week (with raceblades)? 😉
i have just put some crud ones, on my old 70's pug it has campag brakes they fitted very well , they do fit very tight to the tyre tread and side wall , but with the adjustment provided it was possible to get them clear ,,
not sure how well the little furry pads on the braking surface will last
overall well engineered product
Posted : 16/11/2009 6:41 pm
Maybe its just the make/model I had on my last bike, no idea what they were, but they were properly attached, yet the slightest knock would bend the stays, making them rub, which meant when locking the bike up the either the lock, the stand or the next bike to be pile in would add 5 minutes faffing before I could get on my way again,
They were last seen flying over a hedge soemwhere in Berkshire folowed by a streak of expletives so blue they'd make an Italian blush.
Posted : 16/11/2009 6:43 pm
 JoB
"[i]Jo, what's your take on a cross bike for racing and commuting on during the week (with raceblades)? [/i]"
over
Posted : 16/11/2009 6:54 pm
cheers BD, the man himself has confirmed the very same! sure i've got a cork or two lying around!
Posted : 16/11/2009 7:01 pm
they're designed for tyres up to 23mm...
Posted : 16/11/2009 7:05 pm
Won't fit my carbon Defy, so have had to get SKS Raceblades instead 🙁
Posted : 16/11/2009 7:21 pm
I fitted a pair to my Cervelo soloist, no problem on the rear, but I couldn't get the front on without it rubbing and it drove me mad so I took them off again. Wish I'd bought the SKS ones now 🙁
Posted : 16/11/2009 7:25 pm
rtfm or failing that [url= http://www.youtube.com/user/MrJamietom84 ]wtfv[/url]
Posted : 16/11/2009 7:40 pm
 gray
I couldn't get them to fit under my Mavic SSC brakes (with 23mm GP4000), even after WTFV.
Posted : 16/11/2009 9:14 pm
very happy with my crud road racers, but I did have to modify them by extending the rear mudguard down to the BB with a bit of old sks mudguard. Without that extra bit any water picked up would get thrown straight onto the back of my legs and chain.
Posted : 16/11/2009 9:23 pm
adstick - Member
25mm actually
Posted : 16/11/2009 9:25 pm
I like them apart from the pathetic squeaking they make and I just can't adjust them to stop it.
Posted : 16/11/2009 11:25 pm
good guards, used on TCR with Ultegra.
I know two people who have fitted them and have done it wrong so they dont like the crud guards. Shame as I think its a good fix.
The best thing is get a winter bike with mudguard eyes cos none of the race guards/clip on options are the real deal are they.
you will Get kicked to the back of the winter club run
Posted : 16/11/2009 11:49 pm
Anyone found a source of re-usable zip-ties yet?
Posted : 16/11/2009 11:53 pm
My 2penneth.....
I had to take a craft knife to my crud guards as the clearance under the fork on my Scapin was very tight. Think this is mentioned in the instructions as a possibility. But it really didn't take long (would recommend a responsible adult does this for you though) they now work beautifully.
I've got a Peregrine too, & the wheel clearances are huge, so spacers required to get a nice snug & streamlined fit for full length guards. You can get proper spacers but I've just used cork (like Sam in the pic above). Looks spot on & the huge clearance means that I can whip the guards off & race 'cross at the weekend :0)
Posted : 17/11/2009 12:21 am
I think they're great. Million times better than raceblades which look awful, rattle and give no brake coverage.
Posted : 17/11/2009 12:23 am
Oh & worth mentioning that a set of Race Blades has found itself abandoned in a hedge before now.
Posted : 17/11/2009 12:24 am
I like mine....a little tricky to set up so the wee pads don't rub, I thought I had mine perfect then I had to reset them after the first ride and they have been fine ever since. They are a whole lot better than race blades.
The bike I have them on is a Vitus carbon job with very, very tight clearance.
Posted : 17/11/2009 12:26 am
They fit my Trek 1.5 with 25mm Bontrager tyres on....
And I can vouch for the spares replacement - somehow the section of the blade itself that bolts to the strut managed to snap. On reflection I'll admit it may have been more to do with toe overlap turning a corner than poor product.
Anyhow, I sent the old blade back and received a full new set by return, no questions. They even rang me to tell me a replacement was on the way. Excellent customer service!!
Posted : 17/11/2009 1:05 am
Teetosugars - Did I say the Crud Guards were crap?
I think I said the spacer I made was crap "I then tried making a spacer but that was pretty crap", yes the mudguards aren't designed for cross bikes, but they looked a good product so I thought I would try them.
Posted : 17/11/2009 9:24 am
I use the road-racers on my Caad 9 and have found them very effective. They took awhile to fit (with 23mm Conti tyres) but have been worth it. They work well in the wet and look much better than other brands.
Posted : 17/11/2009 1:39 pm
