Crud Raceguards
[Closed] Crud Raceguards
[#2368312]
Just fitted a set, found it impossible to stop the extended bit behind the chainset rubbing . Ended up making another hole and using a zip tie to hol dit to the chainstay and out of the way of the tyre. Aslo took a bit of bending of the rear stays to get it central over the tyre. Not convinced that it is secure enough to stop rubbing whilst in use.
Anyone else had problems with these?
Posted : 14/01/2011 2:37 pm
Fitted them to all my bikes no problem
good mud guard iif a bit slim but it says race on the tin 🙂
Posted : 14/01/2011 3:57 pm
No problem fitting mine. Had Race Blades before and these are miles better.
Posted : 14/01/2011 4:07 pm
