Cotic Soul Rear bra...
[Closed] Cotic Soul Rear brake
[#1162036]
Anyone know the max dia of rear brake you can fit on a Soul? I want to fit 183 or even 203mm discs with my Mono M4s. Ragley go up to 203 rear but there is no information on the Cotic website - anyone got any ideas/ info? That chainstay/ seatstay brace must be able to cope with a lot of braking force. I would be grateful for some advice/ thoughts on this - I have all the other kit collected ready to build when the frame arrives mid Jan.
Posted : 28/12/2009 4:54 pm
It's rarely about braking force, it's about disc clearance on the chainstay/seatstay. I'm not sure, but imagine Cy will be along shortly.
Posted : 28/12/2009 4:58 pm
Cy says it's max 185mm on a Soul.
Posted : 28/12/2009 5:21 pm
i've got a 183 on mine, as brant says seems about the biggest it will take
Posted : 28/12/2009 5:25 pm
Brant - you legend. Top service and it's not even your frame I'm buying!! Having considered a BP but gone for the Soul, you're embarrassing me into thinking I have made the wrong decision! Is 853 really worth the difference?
Posted : 28/12/2009 5:34 pm
Just for the sticker alone, yes.
Posted : 28/12/2009 5:36 pm
Blue Pig and Soul are very different really, both lovely in their own way. Blue Pig is closer to the BFe really, but even so, it's a bit more, well...
I work with Cy a lot, and if all comes to plan, we should have some joint projects coming together next year. We have slightly different ways of doing things, but a mutual appreciation of the steel hardtail.
Posted : 28/12/2009 5:39 pm
A Richards/Turner steel hardtail - that's a brilliant prospect - a justification in itself for bike number 8!
Posted : 28/12/2009 5:46 pm
On my Soul i switched from a 185mm to a 160mm because i found that there wasn't enough clearance to prevent me always catching the rotor on the frame when i was putting the rear wheel back on (it was pretty tight).
I scratched the stays a few times and then put a 160 in there - much better IMO.
Posted : 28/12/2009 5:53 pm
183mm hope saw with some bodge tape on the stay.
Posted : 28/12/2009 6:00 pm
 al
Helicopter tape solves that 🙂
Posted : 28/12/2009 6:59 pm
Running a 180mm fine on the back of mine for many a year.
Posted : 29/12/2009 12:42 am
Intense-Pilot: "Is 853 really worth the difference?"
Just weight really. Soul is quite a bit lighter than the Pig, but then they're very different bikes.
Posted : 29/12/2009 2:46 am
I think you get 15% off for stomach-churningly sycophantic posts as well. something to think about.
Posted : 29/12/2009 10:03 am
