convert solid axles...
[Closed] convert solid axles to QR???
[#1931857]
My sons bike (Islabikes Beinn 24) has solid axles on the rear. I'd really like to convert to QR, mainly so it fits in the boot and so that I don't have to carry a big heavy adjustable spanner in my bag.
So looking for some advice... is it possible? Easy? and what bits will I need?
Thanks
Posted : 25/08/2010 7:43 pm
just a hoolow qr axle and qr
Posted : 25/08/2010 7:51 pm
if the axel has a diameter of 10mm
http://superstar.tibolts.co.uk/product_info.php?cPath=32&products_id=287
will take a few seconds - im assuming that the axels are that size as its the standard diameter for the dropouts on frames
edit
oh its an islabike oops read the post correctly ignore all my bollox above unless its a 135mm spaced rear?
Posted : 25/08/2010 7:52 pm
Nice one Kimbers... it is 135 x 10mm axle
Cheap and easy answer... gotta love Superstar!
Posted : 25/08/2010 8:17 pm
That part won't do the job- you'll need something with cones and a thread (i doubt a kid's bike comes with cartridge bearing hubs).
This is what you need-
http://www.cyclelife.com/Product.aspx?pc=2&pt=23&pg=2207
Yes, it says 145mm (they also do 140mm) but you need some to fit inside the dropouts- so the end of the cones will be 135mm apart, with some extra to fit in the dropout. You'll need to measure your dropout thickness to decide which to go for.
When we fit these to bikes we usually use the cones and bits off the axle already in the hub as there's usually some variation.
Posted : 25/08/2010 8:38 pm
thanks for that Spokes
I've just been playing around with it and it seems you're right... cones and loose balls!
Could the original axle be a different thread...3/8th perhaps? I can't seem to get a M10 nut to go on it? Measures up at about 9.3mm but won't take a new nut.
I'm getting very puzzled now.
T
Posted : 25/08/2010 9:14 pm
Could well be a different thread. The cones on the Weldtite axle will work with the hub just fine though.
Posted : 25/08/2010 9:31 pm
Disappointed no one helpfully suggested drilling it! 😉
Posted : 25/08/2010 9:42 pm
