completely random a...
[Closed] completely random and irregular squeal from disc brake.. any ideas?
[#1557917]
as above really.. no rhyme or reason to it whatsoever.. just starts up squealing with no prior warning. stops for a second or two.. starts again.. stops for a few minutes.. can happen coasting.. on or off the brakes.. pedalling hard.. uphill.. downhill..
like I said... random
any ideas please it's starting to make me a little tense..
Posted : 29/04/2010 2:45 pm
wheel slightly loose in dropout/QR not really tight?
front or rear?
Posted : 29/04/2010 2:47 pm
front.. If anything though I woulda said that the QR was overtight
Posted : 29/04/2010 2:50 pm
squirrel?
Posted : 29/04/2010 2:51 pm
if it happens and you've not just braked intentionally then soemthing is moving, the hub might be a bit 'loose' on it's bearings, for instance.
Maybe the fork legs are twisting under load?
caliper/disc loose?
Posted : 29/04/2010 2:52 pm
buckled rotor?
Also could be wheel out of true, broken/loose spoke?
Posted : 29/04/2010 2:53 pm
Dirt behind one of the pads maybe. Had this problem myself and it led to death threats on group rides. I feel your pain.
Posted : 29/04/2010 2:54 pm
 tron
Are the disc mounts faced? My inbred squealed like hell until they were.
Posted : 29/04/2010 2:58 pm
 Soup
You're not using Kaesae's bearings are you?
Posted : 29/04/2010 4:25 pm
One of the pistons could be sticky and not going back in.
Posted : 29/04/2010 4:35 pm
Take wheels off.
Take pads out.
Push pistons fully in.
Refit pads wheel.
Squeeze hard several times to center brakes.
If it continues check wheel cones/bearings.
Have mounts faced.
Posted : 29/04/2010 8:34 pm
