Coil shock on Pace ...
[Closed] Coil shock on Pace RC405 (or other DW-link style bikes...)
[#1412832]
Anybody tried this?
I've got an RC405 with the RockShox Monarch shock, was thinking of putting a Fox Van R or similar on it.
I heard the rate is unsuitable for coil shocks on this style of linkage (I think it falls quite a bit at the end of the stroke?)
Problem with the current shock is that it seems to have far too much low speed compression damping - so traction is pretty crap and the ride is inconsistent. You get clattered about like you're on a hard tail until you whack a big rock, then it squidges and you're not expecting it!
Posted : 15/03/2010 11:12 am
Certainly DW bikes have a falling rate end of stroke. But I don't know what the Pace does. Linkagey bikes can be quite different, even with similar looking systems.
Posted : 15/03/2010 11:16 am
 LAT
I put a Fox RP2 on mine to replace the DT shock - mainly because the DT had ware on the shaft and CRC were doing the RP2s for a price close to that of a shock service. I didn't have problems with traction, but did find the action a bit squidgy. The ride is now generally more pert. I still get full travel but the action feels more controlled.
Posted : 15/03/2010 11:22 am
Thanks chaps, much appreciated. looking like a better air shock is the way forward then.
Posted : 15/03/2010 12:16 pm
ChunkyMTB got a Push'd Fox Vanilla shock from TF Tuned for his DW Link 5 Spot. He loves it, so may be worth speaking to TF if you like the idea of a coil rather than air and see what they reckon for the Pace.
Posted : 15/03/2010 4:07 pm
