CO2 inflators - any...
[Closed] CO2 inflators - any reliable recommendations?
[#1527333]
Had a couple of dodgy ones-Topeak One Shot-which haven't lasted the distance. Anybody had good, long term, reliable service and can recommend? Smaller the better and presta valve.
Posted : 20/04/2010 4:49 pm
My SKS one seems to have held up and has a plastic cover for the cyclinder to stop hand freeze.
Posted : 20/04/2010 4:51 pm
Got a couple of Tru-flo ones that work well
don't go anywhere near Weldtite
Posted : 20/04/2010 4:53 pm
 Limy
BBB Airspray one is good and comes with 2 cartridges. As above mine is always in camelback.
Posted : 20/04/2010 4:56 pm
what teetoosugars says, down to the box of 30, and 'it's all I carry nowadays'.
Posted : 20/04/2010 5:00 pm
i use a truflo on - have had 2 of them now - last one only got replaced because i lost it !
Posted : 20/04/2010 5:04 pm
16 grams cartridges are goo for 26" wheels but whats good for a 29er, my tyres are a bugger to seat in the rim so i generally have to over inflate first then let so out to the right pressure. would the 25g versions good for this?
Posted : 20/04/2010 5:14 pm
I'm in the market for one of these aswell actually.
The One above looks ideal.
To what psi roughly would a 16g cartridge pump a tyre up to?
Posted : 20/04/2010 5:29 pm
 tron
The zefal type adaptors are fine, tiny and weigh naff all. Best of all, they cost a couple of quid. You screw the adaptor onto the valve, then screw a CO2 cartridge onto the adaptor. As you wind it in, it pierces the cartridge and dumps the entire contents into the tyre.
Apparently a 16G cartridge will pump a 2.1 up to 40 psi...
Posted : 20/04/2010 5:42 pm
i use the innovations air chuck one. Its tiny and works pretty well
Posted : 20/04/2010 5:54 pm
innovations proflate here, and get 10 cartridges of fleabay for £7
Posted : 20/04/2010 6:02 pm
I bought a Giant one as cheapest in the LBS when I needed one quickly. Used with 16gm threaded cylinders from tyre inflators above.
It has seated my 29er tyres no problem, though I have then over inflated them with a track pump to help with the sealing.
Posted : 20/04/2010 6:28 pm
turnercraig - Member
About 40psi for an MTB Tyre... And over 100psi on a Road tyre..
Posted : 20/04/2010 6:29 pm
+1 for genuine innovations - top stuff.
Posted : 20/04/2010 6:44 pm
I've got 2 x [url= http://www.tyreinflators.co.uk/innovations-tyre-inflators/innovations-second-wind-mtb-inc-1x16gm-co2-uses-only-innovations-brand-co2/prod_1097.html ][b]Innovation Second Wind mini pumps[/b][/url] & they have been fantastic with no problems.
They are small enough to fit into a saddle bag or back pocket. I get the 30 cartridges from Tyreinflators & jobs a good un 🙂
Posted : 20/04/2010 6:52 pm
crispy bacon - How good is the actual pump itself? And do they take just normal 16g threaded cartridges?
Posted : 20/04/2010 7:11 pm
turnercraig - the pump is OK but being a mini pump it takes f*kin ages to get the tyre up to anything like a reasonable pressure - unless you have very strong wrists 😉
I tend to use the pump to just inflate the inner so I can put it & the tyre on, then I use the CO2 to fully inflate it in half a nano second. You won't want to go back once you've used CO2 🙂
The pump does both presta & schrader valves & it takes the normal threaded 16g carts i.e. not the non-threaded ones.
HTH
Posted : 20/04/2010 8:25 pm
Tanks evrybuddy.
Gone with Genuine Innovations as per posting above.
Ordered at 2.30pm-arrived 8.30am!
Will hopefully not be tested on Dyfi.
Posted : 22/04/2010 9:28 am
Good choice, been using mine for years now and it's never failed.
Posted : 22/04/2010 9:33 am
ginsterdz - That's funny I want mine for the Dyfi aswell!!
Which one did you go for in the end? I was thinking of going for the second wind pump.
Do they charge postage?
Went for Ultraflate+ and 10 cartridges-£21 with delivery. I always carry a top up pump just in case.
Posted : 22/04/2010 8:10 pm
here too
Posted : 22/04/2010 8:28 pm
