It looks pretty good mate, though bikes without any colour on them pretty much always do in my book.
Got to be said that (having owned the same fork) I think you've got a bit much air in the negative chamber on the fork, mine @100mm looked longer for definite. Personally, I think that bike looks like it NEEDS a 120mm fork on it, to get the angles right, as it is it looks light it will be a bit sharp steering. I think the problem you had with your Menja's wasn't so much that they were 130mm of travel, more that the cr@ppy Magura damping system meant they too readily gave up all 130mm of travel pretty much all of the time. I've had a go on some, and I felt the same way, and you know what the weight difference between us is!
Reba's don't dive quite so much (as you probably know) and a 120mm Reba is a lovely fork indeed.
On the mech hanger front, personally I wouldn't... How much does it really offend you? Remember, you're still experimenting with the bike a lot, if you find you don't like the Alfine, and can't stick with SS (knees possibly), then you'll be needing to stick a mech hanger on it anyway! Versatility is key, and only real SS geeks care about such trivialities as a mech hanger!
Now just stick some PHAT rubber and forks on there, and it'll be super sweet!
