Just a quick one - i just noticed that the little clip that holds the brake pad pin in place is missing. Im ouy rirding tomorrow so no time to get a replacement and i didn't have anything to hand to use as an alternative. Is the pin likely to work its way loose on my ride, keeping in mind the game i had removing the pin a few weeks ago when removing the pads.
On my M4's it screws in so I'd be safe on the Mini I think it just pushes in, so I'd be tempted to twist a staple/wire or paper clip in as a temp measure to be sure it stays in place
if you took it out a few weeks ago it will come out more easily next time, you got some fine wire (fuse wire) or really small safety pins handy?..any of these will do...push em through and twist em into a lump that will stop it falling out...
