Viewing 18 posts - 1 through 18 (of 18 total)
  • Changing loose change machines
  • Bushwacked
    I've got loads of loose change – heard that at supermarkets you have machines where you chuck it in and get it out as something easier to spend but have to pay a fee.
    Anyone used them – are there better ones out there I should keep any eye out for?
    (Sorry wrong forum)
    allthepies
    A bank will change, errrr change for you free. (you may have to bag it up though)
    TooTall
    A bank will probably have a max value. The machines charge something like 5p in the pound – worth it not to have to count it yourself.
    Stoner
    let a charity count it for you? 😉
    PePPeR
    The machines do take a percentage, but banks and building societies make it difficult by only allowing you take in a few pounds worth of change each day, Normally around £5 maximum.
    bruneep
    Take it to a Bank and take a small child with you and tell the bank its from the small childs piggy bank, no charge. 😉
    Teetosugars
    7p in every £1 hardly a major drama..
    And a lot less hassle than bagging it all up IMHO.
    uplink
    No problem at some banks if you have an account & no limit – you do need to bag it up though
    Coop is OK
    Nat West is OK
    not tried any others but I recently took £2k of change into the Coop & they were fine
    I would however avoid busy times
    rob1984p
    uplink, your sofa must be an amazing place…£2k of change, yikes!!
    uplink
    I have a 6 litre beer keg [empty of course] with a slot cut into it that I empty my pockets into every day – so there's usually at least £3 often up to 10 going in most days
    When I fancy something new – I cut it open
    slartybartfast
    Supermarket machines usualy charge 10 percent (robbin bastids), I recently changed 850 quid in loose change at barclays for free. I do not have an account with them, I had it all bagged up ready and just took 250 quid a day in they changed it no problem.
    Flaperon
    I use those machines too, don't mind sacrificing 7p/£ to avoid having to bag it all up myself. Empty in tub of change, collect receipt and all the various foreign currencies and car park tokens from the reject tray. Besides, I like the clattery noise it makes.
    Bushwacked
    Jesus!!! I've only got about £5 but need a brake outer for my daughters bike so am going to use one of those machines this time – once I've saved up more I might try the bank route.
    uplink
    If it's only a fiver just pay for the outer with it
    dobby156
    I just feed them into those self service tills in ASDA, then pay what ever is left with card
    aracer
    Why don't you use your loose change for something more unconventional – like spending it in shops to buy things with? If you do that regularly enough you never build up vast quantities of the stuff.
    mastiles_fanylion
    Some banks now have loose change machines. The HSBC in Northallerton being the one I used – same as supermarket machines but no charge
    duntmatter
    If I break a note, I never put 1, 2, 5, or 10p coins back in my pockets when I'm next going out. I may not manage to spend them, and they just weigh my trousers down. I now have a heap of change, so I think I'll try the machine in Sainsbury's. 7p/£ sounds like a good rate of loss compared to the other arcade machines 😛
The topic ‘Changing loose change machines’ is closed to new replies.
