a quick calc would say would need to weigh just over 7 tonnes to exceed the yield strength of a single plate
you're mixing it up with plastic deformation
whooops - coffeeking is of course totally correct - all materials elastically deform up to their yield point
Easy mistake to make, shows you were thinking in the right direction though!
and elastic deformation is characterised by the material returning to its original length or shape when the load is removed
goes to the back of the class
everything stretches, even glass.
however, glass is brittle, and snaps (or shatters) after very little stretching.
chains do stretch, but only by small amounts, and they will usually return to normal shape unless youre very powerful.
and of course the chain stretchs, to some degree.
solid room temperature granite flows like silly putty, to a lesser degree, but it still does...
eventually.
if you mean, "does the chain stretch when i put my weight on it, to a degree where i would notice, or be affected"
no
differentiation between "stretch" due to wear in the links
and stretch as we know it, due to a porker loading the chain up
is what is needed perhaps?
I don't think that's true, solids are
Chains 'lengthen' with use due to wear on the rollers and pins. they do not 'stretch; appreciably, ie stretch is 1% of chain growth when compared with increase in length due to pin and roller wear.
This is of course why road chains tend to last a lot longer in terms of miles and hours used - they are usually kept cleaner, so will wear less, and remain shorter in terms of length.
I'm interested in how larger gentlemen manage to snap chains, surely the tyre will spin out before the tension in the chain is enough to break it?
what other terms might they have been shorter in ?
plastic deformation only stops when the object is cooled to absolute zero (-270somethingish)
solids are only truly solid at absolute zero.
the same idea applies to glass in windowpanes, whereby glass over 100 years old or so, is noticebly thicker at the botttom than the top, due to flowing down the pane and sagging.
ive snapped chains, and im a portly 11st.
i THINK its more to do with application of load, rather than the load itself, ive only done it whileplaying silly buggers on toy bikes
i think it also only occours where ive done something silly with the pin, like pushed in a normal pin to join a chain, causing a weakness on ones side, allowing the outer plate to be forced to pop off the roller due to slight side forces incurred while the chain is crossed from middle ring to big sprocket.
slight side loads (due to gear selection) + dodgey bodge in a pin + Torque = crotch + stem + "Ow!"
...glass in windowpanes, whereby glass over 100 years old or so, is noticebly thicker at the botttom than the top, due to flowing down the pane and sagging...
That's true - we rotate ours every 50 years.
So if I've read it right
Pitch length increases as the pins and bushes wear.
The side plates are unlikely to be plastically deformed due to creep at standard riding temperatures.
no, at that temperature they just stop molecular vibration
apocryphal. In fact, older glass panes are thicker at the bottom (if at all) due to the casting methods used. Modern glass is cast floating on liquid metal and highly uniform.
This is complete tosh of the finest urban myth sort. Yes glass is not a true crystalline material, being a supercooled liquid, and will "flow" over a (very considerable) amount of time, but not in your, mine or anybody else's lifetime.
Pre tin float glass, panes were made from bullseye glass that was spun out into a disk from a blown glass bubble. The disks were then cooled and cut up into panes. As they were formed from a disk created under centrifical force, they were thicker at one end than the other. In order to make glazing easier, glaziers would place the thicker portion at the bottom of the pane and so joe public naturally thinks that the glass has flowed from the top of the pane to the bottom. The cheapest panes were those from the centre of the bubble where the bowing iron or puntee were attached. These would be really thick and have a round glass bullseye in them.
Good one for QI that. Are you listening Stephen?
ballsofcottonwool - as someone said above, chains almost always snap due to pin/plate joint failure, slight misalignment or lateral forces, or material failure if the chain fatigues in the middle of the plate (rare). Technically you should never find a bike chain that has snapped due to a plate failing in plain tension.
As hot_fiat says, glass creep takes immense amounts of time, longer than a window would remain a window.
how is placeing a window pane with one theoretically minutley thicker end at the bottom, any easier than placing it any other way up??
molecular vibration only stops completly at absoloute zero
i stick to my guns, but cant be bothered to argue it :p
ball of cotton wool has it
I am also interested in how "larger gentlemen" break chains. I doubt they put more load thru them that we do on the tandem. 22+ stone of us jumping on the pedals in 22 / 34 granny puts frightening loads on the chain - a load of nearly a tonne along the chain. ( and 4 tonnes on the pawls in the freehub) We break freehubs but not chains. At that level its not a function of fitness but of power and leverage - and with both of us putting all our weight on the pedals few solo riders will be able to match that.
IMO chains break either when they are badly worn or when you make a mess of a gear change
perhaps the fatties are just daydreaming about pies and stuff when they should be concentrating on clean gear changes ?
