Chain Skipping
[Closed] Chain Skipping
[#901165]
This is occuring on the 2nd-4th sprockets on my cassette. The entire drivetrain is new (SRAM cassette & chain, SLX rings & BB on a Helius CC with a single BB spacer on the LH crank side & 2 on the right). The rear mech is XTR.
Exactly the same thing had been happening with my old drivetrain, but I had assumed that it was worn components. Clearly I was wrong. What else could be the cause - the mech hanger? It's not obviously bent, & wouldn't it affect shifting over the entire cassette?
Posted : 27/09/2009 12:33 pm
Just throw this out there.. are you running the correct shifter for your gears? I was running a 9 speed shifter on an 8 speed cassette for a while and experienced a very similar problem (it was desperate times!).
Posted : 27/09/2009 12:47 pm
It's all 9 speed & used to work perfectly.
Posted : 27/09/2009 12:50 pm
no worries, sorry I can't help mate
Posted : 27/09/2009 12:53 pm
I'll take a SWAG (Scientific Wild-Arsed Guess) at this and say...gear cables. Make sure they're clean and lubed and maybe it'll solve your problems.
Posted : 27/09/2009 12:57 pm
How olds the chain?
yeh, your kit's all ruined. Tenner for the rear mech ?
or clean/replace your cable(s) is favourite - could be the hanger but shitty cable is most likely
even so, I think a tenner's fair 🙂
Posted : 27/09/2009 1:42 pm
I cleaned the cable...............& it all works!
The old kit will be put back on to see if I have just wasted a load of cash.
Posted : 27/09/2009 11:14 pm
"Stiff link ??"
This will make the chain skip on the small cogs only
Posted : 28/09/2009 7:25 am
Had some lovely suggestion and then read that you'd claened the cables and solved it.
Posted : 28/09/2009 9:32 am
