Recently put a CCDB coil on my five, I’m 80kg in gear and run it with a 550lb spring, had a 500lb on and felt a bit too soft, seems a heavy weight spring for me to be running but the sag and feel when riding is spot on.
Used these settings as a starting point from the website.
HSR- 1.0-1.75 turns in from all out. HSR controls the shock from the bottom of the stroke if you feel like you’re getting bucked add .25 clockwise till the feeling goes away.
LSR – 8-12 clicks in from all out
HSC – 1.5-2.0 turns in from all out. If too harsh and not reaching bottom open counter clockwise. Allowing the shock to get full stroke.
LSC – 10-15 clicks in from all out
Added half a turn of HSC and a couple clicks less LSC and it feels brilliant. Them settings are a good starting point anyway, then tweak as you feel necessary. And enjoy, it’s transformed my five both on the uphills (surprisingly) and especially the downhills!
Spower
