Carbon Post in Carb...
[Closed] Carbon Post in Carbon Frame, do I need to use Carbon Paste?
 Jase
[#3768281]
If using a carbon post in a carbon frame should I use carbon paste or is that just for use in an aluminium frame?
If yes, any suggestions for paste?
Thanks.
Posted : 13/03/2012 11:04 am
Yeah carbon paste in the frame stops it binding and siezing in also it has granuals that create extra friction so less clamping force is needed to hold the post in.
Posted : 13/03/2012 11:11 am
 Jase
Ta.
Posted : 13/03/2012 11:14 am
As above it's good practice, but I've been using carbon posts in carbon frames for 12 years, 99% of the time never using carbon assembly paste and often not moving the seatpost for years at a time, and never had a problem.
Posted : 13/03/2012 11:15 am
Ahem. I used ordinary grease on mine - is it going to kill me?
Posted : 13/03/2012 12:01 pm
Yeah you will die 😯
Posted : 13/03/2012 1:47 pm
14 years for me 😛
Posted : 13/03/2012 1:48 pm
 D0NK
what if you are a saddle dropper, carbon gunk or don't carbon gunk?
I presume (and do) the latter
Posted : 13/03/2012 1:52 pm
Probaly better not to drop the seatpost as the stress caused in mutiple places can cause failure and carbon shards in the rear could hurt
Posted : 13/03/2012 2:09 pm
 D0NK
sorry shorty but this sounds like made up science to me*.
besides saddle is dropped to get it out of the way so don't spend much time sitting on it.
*no as it happens, I'm not a structural engineer, how did you know?
Posted : 13/03/2012 4:40 pm
If you got it, use it, if not, then not really much loss 🙂
Posted : 13/03/2012 4:46 pm
If you don't have paste, spit in the seat tube. When spit comes into contact with carbon fibre is stays moist indefinitely.
Posted : 13/03/2012 5:28 pm
it's friction paste so it doesn't slip, it's not some sort of anti-seize thing.
Posted : 13/03/2012 5:32 pm
What lube for carbon shards?
Posted : 13/03/2012 5:39 pm
