I need an I-beam post in 31.6.
Not much in stock from SDG, although I see Kore I-beam and "T-Rail" posts - presumably these are the same except for the branding?
Any other post makers doing I-beam compatible posts?
Thanks
Well Silverfish have stock. I can order if you like if you have problems in sourcing one.
There is:
31.6x350mm aluminium for £40,
the micro aluminium 31.6x400mm for £53,
the micro aluminium 31.6x400mm layback for £53,
the carbon micro 31.6x300 or 400mm for £75.
workshop@thecycleclinic.co.uk
Thanks, that's useful.
Need to check the frame, but 31.6 x 300 might be the jobbie. need to get a feel for the layback as well. Previous near identical frame had 15deg layback Ti post
