I have been using Prestivo tyres on the front of my Picasso for 20k miles on a 185/65/15 and alas mrs SD hit a pot hole and blew the tyre out. I checked the warrentee and found this below
Prestivo Accidental Damage Guarantee.
This tyre is guaranteed against accidental damage – that means if you damage it and we cant fix it we will give you a discount on your replacement tyre of up to 100%.
The discount is based on the unused portion of the tread, so if the tyre is unworn you get 100% discount, 50% worn, 50% discount. 90% worn 10% discount. Simple!
Prestivo is made by a leading manufacturer and combines great handling especially in the wet, with class beating durability….Check Size Availability
Tread Remaining Discount
8mm…………100% allowance
6mm-8mm….75% allowance
4mm-6mm….50% allowance
2mm-4mm….25% allowance
below 2mm….nil allowance
Returned to the tyre dealer, no quibble replacement tyre £15
These tyres ar £56 each which is £35 less than equivelant mitcheline’s (which at 20k are knackered) and should be good for 40k+ and I have never had any grip issues with them so perhaps Cheap tyres can be good
