Did you check it when it was cold or hot ( yes it makes a difference ) ?
Do you know for definite that it was at a higher level before? As already said, The issue is more whether the amount is actively dropping as time goes on indicating a leak – so you need to monitor it weekly (or daily) It *may* be that it was simply filled to a lower level from a service and its been like that for ages with no leaks. Although at 18months old, I would expect it to not have had a coolant change as yet.
Sometimes, with all the best will in the world, there are so many coolant pipes and joins in modern engines that you simply do get tiny leaks that are all but impossible to trace – but they are so small that they only lose tiny amounts of fluid over long long periods. So long as the coolant in the tank remains at suitable level, then it should be fine.
My big 4.2 V8 engine must drop about 100ml of coolant over about 3 months. I just monitor it and top it up once in a blue moon. I don’t see any leakage visible but can smell it after a run – Its just one of those things, and its certainly not worth the hassle of stripping down the engine bay for a tiny leak.
