With loads of sag the fork will dive heavily under braking, on steep stuff, in corners and generally feel quite sloppy and uncontrolled
A fork too tall for a frame will make the BB hieght higher making it worse in corners, harder to get on/off and get started on tricky climbs/traverses/DHs
The effective top tube length will shorten
The chain stay length will probably increase on a XC hardtail (depends as to the angle)
The headangle will obviously increase, but will still dive to the same point
Most importantly though, the seat angle will be a lot slacker making it more difficult to ride in pretty much every situation but downhill
The increased travel has the potential to rip the headtube off too
Given its an 80mm frame I’d try to stick to a 80, 85, 100 (maybe a 105) fork, not just because they’ll likely be lighter, but much more suited to the frame
