• This topic has 3 replies, 3 voices, and was last updated 10 years ago by gra.
Viewing 4 posts - 1 through 4 (of 4 total)
  • calling gear experts – gear ratios, 32 11/34 to 34 11/36
  • gra
    Hi all,
    I am upgrading from 1×9 to 1×10 and wondered if the above change would give me similar low gear, but a bit more higher gear. I’ve looked at the Sheldon Brown calculator etc. but the numbers don’t mean much to me to be honest.
    Would a 33t give me a bit more each way or would difference be minimal?
    Many thanks.
    richmtb
    34 / 36 is ever so slightly higher then 32 / 34, but you would never notice
    34 / 11 is higher gear then 32 / 11 and will be a difference you would notice (the difference would be similar to your two highest gears now)
    ahwiles
    gra – Member
    a 33 could be just what you’re after, but remember that you can’t get a thick/thin 33er (or any odd number for that matter*)
    (unless you live in the 4th dimension)
    gra
    Thanks for the replies, that helps. Yes, was looking at the Raceface thick/thin in 34, or a Renthal in 33, paired up with a KMC chain.
The topic ‘calling gear experts – gear ratios, 32 11/34 to 34 11/36’ is closed to new replies.
