Pressed in a Superstar tapered headset last night, went in fine and easily up till right at the last minute. There is a very small (maybe 0.5mm) gap between headset and lip of the headtube. Any other C456 owners had this problem?
Could be i’m not using enough brute force and ignorance.. but id feels like any more force would be more than it should need. I’m still scared of over torquing anything with carbon near it.
I’m guessing there could be a bit of a radius on the lip of the headset cup which is causing it as the gap is equal all the way round and on both cups, but the problem with it now is I don’t see any way of easily getting the headset out. Top cup should come out fine with a removal tool, but the bottom cup sits up against the internal lip of the headtube insert – I can’t see any way of the cup remover getting any purchase on it, and I don’t have a 1.5″ removal tool to try.
Anybody removed a lower cup from one of these frames without destroying anything? Or should I just smack it with a hammer until it sits flush… 😉
