I thought you were chancing your arm a bit with the OP there warton. 😉
we find that the kitchen floor consists of chipboard, on a framework. I know, after speaking to other builders that this is shocking
A lot of builders still use this method for a sub-floor. What might have been shocking would be the method used for fixing the framework. Also, the chipboard should be water resistant – that greenish stuff mentioned earlier, or P5. Not sure T/G chipboard that's not P5 would be against building regs though…is it?
Also, chipboard is best screwed down. Nailed down tends to squeak after a while.
Shocking is someone attempting to stick tiles to something without knowing what it is
Harsh, but true.
