Viewing 26 posts - 1 through 26 (of 26 total)
  • building a block shed
  • DT78
    Anyone built one recently? Quite fancy giving it a go myself. Are there any decent guides online? Plus any ideas what sort of budget I,d be looking at? Approx 10 by 8.
    highclimber
    10×8 wont be big enough i’d go for 8×10 for extra width
    DT78
    Kind of limited by the site, it,ll be replacing a rotting 6 by 4, so reckon it,ll be ok for me
    bellys
    Why not buy the panels from eBay look for Concrete garage it might be cheaper and easier.
    highclimber
    something like this?
    DT78
    Reckon it would be quicker to build out of block than Lego :). And prob cheaper too! Will take a look for concrete panels – hadn’t thought about that
    ernie_lynch
    Why do you want it out of blockwork ? Unless of course you’re a bricklayer, in which case you don’t need any advise. Otherwise I would go for timber. Carpentry is a piece of piss, plus a timber shed looks nicer, unless you give the blockwork some sort of rendering – more hard work. And then you’ll probably want to paint it, something which will have to be done regularly if you want to keep it looking pristine.
    BTW, it’s probably cheaper (and easier) to buy a shed than to buy the materials and build it yourself.
    Buy a shed.
    highclimber
    more security?
    ernie_lynch
    Well I’m guessing the door will be out of timber, so it will be as secure as the timber door.
    wrightyson
    Ernie is right!
    Stoner
    timber far more fun to work with
    And can be adapted more easily.
    Currently re-jigging the wood store into a wood pellet tank
    DT78
    The site is not straight so unless I stick with a 6 by 4 I won’t get a much bigger one in. Looking at pre builts they are £ 500+ want to get an idea of the cost of materials from people who,ve built their own. Would rather block as it needs less maintence than wood.
    Oh and I fancy a project for the summer….
    DT78
    Stoner that looks huge. This will be the first time I,ve tried anything more advanced than fitted cupboards.
    wrightyson
    😆 stoner, with it being block work you could safely put a wood burner in there, (go on stoner just one more time)
    Blocks circa 60p each, 10 to the square metre. Simple 4×2 roof at 400 centres, lath and felt, slate/tile roof, pointing to verges/ridges. Lotta work, it’s a mini house really, you need to think base/founds first really cos you can’t go building a block shed of reclaimed 3×2 slabs!
    Stoner
    10′ x 13′ ish if you exclude the lean-too
    size isnt really an issue, the construction is much the same, although for smaller floor areas you can probably go for a less substantial roof.
    A spirit level and a bit of gumption and off you go.
    Stoner
    wrighty – do it properly son! Bit of cast concrete insulated former is the way to go, shirley?! 😉
    wrightyson
    I’d centre it all around the log burner and wood stack tho 😉 😆
    However I’d suspend a pre shuttered and poured floating flue at the centre of the shed to add some “industrial” feel to it all!
    Apologies DT78 for the ridiculous hijack, we can actually help if you want.
    Stoner
    put it in the corner, not the middle…
    ernie_lynch
    wrightyson
    Is that In your gaff stoner?? Not seen that one before. Just shown the wife and she said to me is that the bloke who’s doing that beautiful house up 😐 you’ve clearly made an impression and raised “her indoors” expectations of what my building skills can produce, cheers mate!! 😆
    ernie_lynch
    Stoner
    dont worry, not mine.
    Mine is far more discrete:
    But Mrs wrightyson obviously has great taste and an acute memory 🙂
    but something Ive always wanted was one of those scandanavian corner stoves with tiered tiled steps up the outside that the family would sleep on. Couldnt find a decent pic. will go and look again…
    Stoner
    😉 @ ernie
    ernie_lynch
    Thank **** for that 😀
    Well I deleted my post anyway.
    I think your shed looks beautiful btw 😉
    amodicumofgnar
    Oh, I’m having Sunday night shed and stove envy.
    Stoner
    here we are, a masonry stove:
The topic ‘building a block shed’ is closed to new replies.
