Stooge Mk3 is available soon.
This will be my third and I love it. Will also be available in two sizes.
Ceeing as you asked, here’s a little info on the MK3. First off, they’re being made at the moment, i’d like to say 3 months away but these things have a habit of dragging out a little. So, 2 sizes – the current size with a 18″ seat-tube and a 23.5″ top tube, and a 20″ with a 24.8″ ETT and slightly taller headtube. 44mm headtube, tapered steerer steel fork, 15mm shorter chainstays (430mm + or – 7mm due to EBB), fatter downtube, slightly fatter top tubes. I’ve stuck with a 27.2 post because of the comfort, plus there are plenty of 27.2 droppers available now.This new one is optimised around B+ because i love the way it rides, but you can still run 29 rear/29+ front if you want.
Why a 44mm headtube? Couple of reasons really, a lot of people wanted to run a carbon fork on their MK2’s but couldn’t, and the axle to crown of the fork is the same as a sagged 120mm B fork or a 100mm 29er, so if you really wanted to you could.
