Never been quite sure why, but I never see any Trek’s on here.
Anyway, after a season as a bike guide in Turkey, riding a Trek X-caliber 9 for 6 days a week for 27 weeks, I wanted a new bike here at home! Bit of a case of sticking with what you’re used to, I managed to get a current model Superfly 6 for £600. It’s a 17.5″ frame, and I’d probably be better on an 18.5 with a shorter stem, but hey-ho!
So, after 6 months of almost all dry, rocky and gravelly trails, and prior to that a several year break from MTb’ing (I winged it very convincingly in the interview!), I thought I’d take the new bike out. Thankfully the previous owner shipped the bike with a Bontrager Mud on the rear! He also appeared to have cleaned the stickers off the forks and wheels, for a nice clean look!
So, an almost stock 17.5″ Trek Superfly 6 with these bits fitted:
FUNN Full On 785mm 30mm riser bars
M530 SPD’s
ISM Peak saddle
I spent a little while today getting used to it – it doesn’t feel a whole lot different. Slightly lighter, and I’m used to 3×10, not 2×10, so I ended up spending my entire time in the ‘big’ ring, powering along. It helps I’m pretty fit now!
Saddle isn’t as far back as the stated ‘max’ on the rails, so I’m quite happy with it. ISM’s are nose-less, so it looks stumpier than a normal saddle would.
I always store my bike’s small ring, small ring. No cable stretch that way. The chain DOES need a link taken out though, I literally only ‘put it together’ yesterday. I only landed in the country yesterday too!
I have ISM saddles on all my bikes and can confirm that one is about right, albeit pretty far back. As the OP says, they are nose less, so front of it should be 5cm back from your regular saddle as a starting point. The back 5cm or so is never used.
