Brake pad choice fo...
[Closed] Brake pad choice for Alps trip
[#1483942]
As the title says really. I'm off to Les Arcs in the Summer I've read that sintered pads can overheat very quickly on the long descents, and that ceramic pads are a better choice. I've never had any drama's with sintered pads before, but haven't ridden descents anywhere near as long as what i'm expecting in the Alps.
Am i correct about the ceramic pads being a better choice?
Posted : 06/04/2010 6:57 pm
You'd be better off making sure your brakes are fully bled rather than worrying about which compound. Sintered do heat up quicker, but not massivly so IME. Brake less / stop more is the answer!
Posted : 06/04/2010 7:01 pm
Bleed those brakes first, and should not be a problem. Just take lots of spares. I went through 2 sets (on the front) in one week with Trail Addiction.
Posted : 06/04/2010 7:37 pm
I was told to take loads of spare pads on our first alps trip last year.
So took 4 pairs each....how many did we use?.....None!!!!
Both our bikes were using Organic Hope pads BTW.
Posted : 06/04/2010 9:39 pm
If it's wet then sintered, if dry then organic. My sintered squealed like a banshee very quickly on downhill runs in a dry Les Arcs week last yr, put some organics in and no noise. The sintered performance didn't drop off but the noise was crazy loud.
Posted : 06/04/2010 9:45 pm
well.. i'm surprised you didn't use more than one set 'nickegg'. But then, i do tend to over-commit on my riding speed into corners.
Mine were standard Hope Moto V2 pads. So a big brake to start with, but still wore them out.
Posted : 06/04/2010 9:57 pm
I also took 4 sets to Les Arcs a couple of years backs and never actually wore out the original Hope pads.
Have used sintered pads in Verbier the last 2 years (bigger, steeper hills) and have yet to wear out a set in a week.
Posted : 06/04/2010 10:03 pm
I've been out to Spain twice now and have only had to change one pair of SSC organic pads - and the originals were pretty dead to start with.
I think if it's dry the pads don't wear so quickly as they aren't abraded so much by all the grit, even though they have to do a lot more stopping compared to the UK.
Posted : 06/04/2010 10:12 pm
