Biopace was a good idea.
Just 90 degrees out ending up in wheelspin/stall/wheelspin/stall.
Not at all, common urban myth that…
From Sheldon Brown:
Biopace is a patented non-round chainwheel design made and licensed by Shimano. To a casual glance they resemble elliptical chainwheels, but on closer examination they turn out to be the exact opposite of the classical elliptical design. The product of extensive research and computer-aided design, Biopace chainwheels have the small radius engaged when the cranks are horizontal, the large when they are vertical. This is because the Biopace design is based on a dynamic analysis of the motion and momentum of moving cranks and legs, unlike the static, geometric analysis that produced classical ellipticals.
The theory is that during the power stroke, when the cranks are more or less horizontal, you are using the power of your legs to accelerate your feet, which get going quite fast in the lower gear provided for that part of the stroke. The momentum of your feet then carries the pedals through the "dead spot" when the cranks are near vertical. Since the rider doesn't push as hard during the power phase of the stroke, and motion is slower when the leg is changing direction, the Biopace design is gentler on the knees than even round chainwheels.
_____________________________________________________________________
Those Osymetric ones are similar to the Rotor rings, elliptical chainrings are back in fashion.
